Son's first car, bought with his money!!
Posted By texasmark1 15 Years Ago
So it didn't bog before messing with the distributor?
Double check the dwell of the points.  Check the initial timing.  Observe the operation of the mechanical advance to ensure it is operating smoothly.  It should not advance immediately off of idle but it should start relatively close to idle.  If you use a tach, it should start advancing before 1500rpm.  Disconnect the vacuum advance to see if the problem goes away.
Since you did change timing, it can also be fuel related.  It may have been tuned well before but now you need to go back and make adjustments, possibly to idle screws and the accelerator pump.
texasmark1
Posts: 650, Visits: 2.7K
we actually had the wrong dizzy, so a return and correct one ordered...
hopefully will have it in tomorrow, retimed and see what happens
took the hood off this afternoon to clean up the hinges, install the fender aerial and front fender stainless trim.
thanks for the suggestions.
texasmark1
Daniel's Merc is finally rounding third on the way to home plate! Minor carb adjustments to be done Monday.  We plan to complete installing the final stainless trim tomorrow.  Interior is all done.
the beast looks pretty fine. He's finally decided on a name for the car... "Donna".  He has in the past been accused of favoring Eric Forman on "That 70's Show"... whose girlfriend was named "Donna"... so...
Daniel will put up some video hopefully Sunday of his car in action.  When he does, I will post the link to youtube where he has previously posted a couple of short videos.  this one will be longer.  I hope to capture his pride and joy, along with him, for your viewing pleasure and to say a big "Thanks" to al who have given us encouragement on the forum.  And to a few who have generously donated parts for him.
Mark
texasmark1
https://www.youtube.com/watch?v=PdnnqGooScQ
closer than he's been before today!
is it finished? mostly
is it perfect? come on, its 51 years old
is Daniel proud as punch? you bet.
the link takes you to a short vid shot earlier today.
enjoy, Mark
MplsMike
Last Active: 9 Months Ago
Posts: 204, Visits: 92.3K
Very nice! Congratulations!
MplsMike
'56 Parklane
Minneapolis, MN
Posts: 4.6K, Visits: 39.5K
Fantastic job you guys have done. He'll be the envy of his class! Chuck
jonnireb
Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)
Posts: 107, Visits: 1.4K
Great going, guys you did it. Perfect? Finished? Probably not, but you don't
ever want to be at a place where there is nothing more that can be done to it.
55f100
West Monroe,La.
YBLOCKMERC
Posts: 194, Visits: 20.6K
Congrats! I'm a Merc guy and it's been fun to watch the process over the last couple years. What a journey you two have had with that car. It looks so fine and you should be justifiably proud. Way to go!
Hope the drive to school went well and Daniel is having as much fun driving it as he did restoring it.
Marc
'54 Merc ragtop
Pt Townsend, WA
      http://forums.y-blocksforever.com/uploads/images/e83cf74f-a3dc-4e1a-a928-8075.jpg
stlroken
Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)
Posts: 113, Visits: 4.8K
That is one GOOD LOOKING Merc...you both should be proud.Love the color.
Jim
texasmark1
Well, we made it from Houston to Abilene (approx. a 6 hr trip up beautiful Texas Hwy 36)!
checked the oil level at the first fuel stop... still at the full mark, temp ok and oil pressure ok.
then about 30 minutes from Abilene, Daniel called me ( I followed him up just in case) saying that he just noticed the oil pressure had dropped to zero, but no temp rise, no funny noises, not smoke, no nothing...
so, we gingerly proceeded the rest of the way.  Upon arrival at his dorm, we checked the dip stick and it was showing no signs of oil!
removed the drain plug and got approx. 2/3 of a quart out of the pan.
proceeded to crawl under and sighted some wet spots in the area of the torque converter housing at the back of the block.  While following Daniel, I noticed a few signs of minor smoke from the tail pipes... not black or blue, just looked like steam.
proceeded to refill the oil up to full level (about 3 quarts), started it up and it ran just fine.
Went over the next day to my brother's shop, jacked it up, crawled under again and found, I believe, where the oil is coming out.  appears to be blowing out at the back corner of the p side head.  perhaps a faulty head gasket...??
anyway, we changed the oil and filter, started right up, no visible oil leak... it must leak at speed on the road.  He drove back to his dorm and parked for the day.
Daniel called me today saying he had a chance to try the strength of the rear bumper... a rear time came undone from the wheel... no blow out... just seemed to come loose from the rim.
So, he's continuing to learn the joys of operating an old car!  But he's a trooper... hasn't dampened his spirits.
His soph year is under way as of today.
will update as interesting things happen.
again, thank you to all who have offered suggestions, comments, words of encouragement, etc!
Mark
