Bonneville results
Posted By Hollow Head 14 Years Ago
Hollow Head
Posted 14 Years Ago
Last Active: 4 Weeks Ago
Posts: 1.0K, Visits: 3.8K
So far this is what I've found.
416 D PP Y-Block Guy Racing 119.611 115.943 120.072 120.072
416 D PP Y-Block Guy Racing 118.471 111.824 119.895 119.895
I quess they haven't run since August 13th ?
And this info comes from SCTA sites, so I think this is the truth!
yblock32deuce
Posted 14 Years Ago
Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)
Posts: 173, Visits: 1.5K
word today is that keith in his 32 cpe. ted eaton yblock engine made his first pass at 153 mph.
BIGREDTODD
Posted 14 Years Ago
Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)
Posts: 324, Visits: 2.4K
Tim & Charlie swapped the modified C1TE heads for the heads off the Brick yesterday to see what difference they make...should make another run today. Truck is running & handling very well.
Todd in Central California...about half way between Fresno and Sacramento
1956 Thunderbird - 1960 F-100 - 1961 Starliner - 1961 Imperial
BIGREDTODD
Posted 14 Years Ago
update
...5 minutes after the post above I received an update...after the head swap & open headers, he ran a 127 MPH...Cool
BRT
57 ranchwagon
Posted 14 Years Ago
Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)
Posts: 69, Visits: 303
Great to hear just saw that on SCTA web site today, does any body know what record Tim's class is running on(can't remember his CID). Also anybody know what car number Keiths 32 coupe is. Best of luck to all the Y-blocks out on the salt go fast stay safe wishing I was racing with you. Thanks also to all who are keeping us updated. Sam
57 ranchwagon
Posted 14 Years Ago
Here are the results from Mondays run SCTA results are running a few day behind.
416D     PP     Y-Block Guy Racing126.532122.336127.049
416D     PP     Y-Block Guy Racing124.375118.478125.194
416D     PP     Y-Block Guy Racing119.096119.544117.338
mctim64
Posted 14 Years Ago
Posts: 2.4K, Visits: 5.0K
57 ranchwagon (8/15/2011)
The record in my class is 164.230 mph.  I had no dreams of reaching that this year, I did however want to make 130 but 127 will have to do.  As Todd said the truck runs strait and true at speed so now it's time to add some power.  165 is not going to be easy, Keith has 525 hp in a coupe and has worked hard to get it to 173.  My engine is smaller and I have a bit more frontal area, the wait isn't an issue and I will be adding it as the speed goes up. Talking to Norris Andersen who holds A/MP and AA/MP records and is basically the fastest pickup out there ('49 Stude @ 220+) he adds 1200lbs to the back of his truck to keep it stable.  Once you get the mass rolling it has a flywheel effect, 'course then you have to think about stopping it. Wink
mctim64
Posted 14 Years Ago
These are the timing slips from our last day, Mon., after the head and manifold change.
My best timing slip,  close to perfect run.
second run on Mon. set the timing to 40* btdc from 35* and see what happens.  Ran good, just not as good.
Last run of Mon. we were hoping for good things with a carb spacer change and the timing set back to 35* but after the first mile the engine got a little rough and you can see what happened to the speed. Haven't had a chance to see what is up with the engine but I'll bet it is a small thing.  I didn't feel the need to take my foot out of it.
bla bla bla
aussiebill
Posted 14 Years Ago
Posts: 1.8K, Visits: 11.4K
Congratulations tim from us all! I think we all need to put it in perspective, you built this truck in a very proffessional manner and very short time, went to the salt passed tec, ran the truck and did actually compete! A great achievment from you, family and other y block guys. Smile
 Down Under, Australia
Posted 14 Years Ago
Posts: 6.1K, Visits: 442.8K
On the time slips, what is SP and DA?
