1957 312 Y-Block for sale in Kentucky
Posted By Jeffs54Merc 14 Years Ago
Jeffs54Merc
Posted 14 Years Ago
Last Active: 14 Years Ago
Posts: 95, Visits: 469
I bought this engine with hopes of planting it into my 1954 Mercury, but I sold the Mercury. The 312 came out of a 1957 Ford Fairlane. I was told that it came from a 57' Thunderbird, but it is missing the water pump spacer.
The engine runs strong, but it needs valve seals replaced in the heads.
Asking $700.00 firm and you pick it up. call me at 606-310-3149
Jeff Leydig
Stallions Auto Interiors
Stearns, Ky. USA
Jeffs54Merc
Posted 14 Years Ago
I am dropping the price for this nice engine to $500.00. This is a good engine and it does run stong, just don't have a need for it anymore. you can call me at 606-376-3149
Jeff Leydig
Stearns, Ky. USA
Noob
Posted 14 Years Ago
Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)
Posts: 158, Visits: 1.8K
I need a running motor for my truck while rebuilding another over the next 12 months... iI could transfer some good heads... is the compression good?
Also, are you willing to strap it down good to a skid or in a crate and get it to a local freight depot or business with a loading dock?
Cheers... Brian
Cylinder Index = 84
Current Experiment = `57 Tbird, Grand Rapids, Michigan
Posted 14 Years Ago
Jeff: Unless the transmission is removed and the crank flange checked for markings, or the pan is removed & the main caps checked for stamped letters, there is no way to determine for sure the engine is a 312,.. cause the block castings in most cases were the same for 292s. Can you check it out & post what you find?
Jeffs54Merc
Posted 14 Years Ago
I have checked it with the trans off before and it is a 312. and it is dated Nov 1956
IT IS SOLD !!
Jeff Leydig
Stearns, Ky. USA
