Dyno results for a 343” Y with aluminum heads.
Posted By Ted 15 Years Ago
Posted 15 Years Ago
Last Active: 11 hours ago
Here are the dyno results for a 343” Y using a set of Mummert ported aluminum heads.  It’s a 343 incher by lieu of a 3.810” bore and 3.76” stroke.  The compression ratio is 13.25:1 using Diamond popup pistons designed specifically for the aluminum heads.  The camshaft is a symmetrical Isky grind with 263° @ 0.050”, ground on 108° lobe centers, installed at 106½° intake lobe centerline, and 0.592” lift.  The rocker arms are Harland Sharp 1.6:1 roller tipped units assembled on Verne Schumann shafts.  The carburetor is a Holley 780 cfm dbl pmpr which sits atop a 2” tapered carb spacer and a ported Mummert aluminum intake.  Spark plugs are Autolite 3923’s gapped at 0.035” and using a MSD distributor and ignition.  Click the link for the larger version of the dyno sheet.
Link to the dyno sheet
yehaabill
Posted 15 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
Ted "Y-GUY"      Will this engine be in anything at Columbus this year?
                                                   Bill
Bill
Pelham,Al
aussiebill
Posted 15 Years Ago
Posts: 1.8K, Visits: 11.4K
Ted, extremley impressive figures, what fuel do you run in this? thank you. regards bill.Smile
 Down Under, Australia
John Mummert
Posted 15 Years Ago
Posts: 919, Visits: 7.5K
Another great job Ted!. It will be interesting to see how fast your Y-Block can push Keith's 32 down the salt.
http://ford-y-block.com
landspeedy
Posted 15 Years Ago
Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)Supercharged (109 reputation)
Posts: 68, Visits: 342
Ted, I keep re-reading the sheet,mighty impressive to say the least.
I think we will make some believers in the y block @ speed week.
John, thanks again for getting the heads & intake to Ted in time for Bonneville.
                                               Keith
its not how fast you go, its how you go fast.
mctim64
Posted 15 Years Ago
Posts: 2.4K, Visits: 5.0K
That's what I need in the Uni next year. Wink
Posted 15 Years Ago
yehaabill (8/4/2011)
Ted "Y-GUY"      Will this engine be in anything at Columbus this year?  Bill
Not a drag race engine but a land speed engine.  This one will be in Keith’s ’32 at Bonneville in a week or so.
Posted 15 Years Ago
aussiebill (8/4/2011)
This engine was tested using VP 110 octane fuel.  This is obviously not a pump gas engine with the compression ratio being that high.  On a cubic inch basis, this engine is handily outscoring the EMC engine and the compression ratio is responsible for much of that.  The aluminum heads sure makes that power much easier to achieve.  The torque band on this engine is equally impressive.
Don Woodruff
Posted 15 Years Ago
Posts: 190, Visits: 1.6K
Man that is pushing a lot of Horse power out of 15/8 headers. Great job.
Y block Billy
Posted 15 Years Ago
Posts: 1.6K, Visits: 5.2K
Too blown away to comment Ted!
55 Vicky & customline
