3 Webers on a 573 intake?
Posted By MarkMontereyBay 15 Years Ago
MarkMontereyBay
Posted 15 Years Ago
Posts: 733, Visits: 3.8K
Has anyone tried making adapter plates to mount 3 Weber 2bbls on a Edelbrock 573? I see that some Flathead manifolds are being cast to use 3 Webers. Seems like it wouldn't be difficult to make some aluminum adapter plates. That would allow for 3 carbs with better CFM than 94's.
57 Black Tbird 312/auto
John Mummert
Posted 15 Years Ago
Posts: 919, Visits: 7.5K
Mark, it would be possible to install 40DCNF Webers on a 3-2 intake but I don't know of any adapters. Maybe rottenchester 4-bolt to Holley 3-bolt if available.
http://ford-y-block.com
yalincoln
Posted 15 Years Ago
Posts: 382, Visits: 4.9K
mabey a weber 3x2' to 4bbl adaptor and use a mummert intake if you're going to all the trouble?
MarkMontereyBay
Posted 15 Years Ago
John Mummert (6/3/2011)
John, I was thinking of three of these. I don't know much about the Webers other than the progressive one Ford ran on the Pintos.
http://www.thehotrodcompany.com/shopnow/show_dept.asp?dept_id=50&filterkey=adapter
I looked around the web and found a UK company, Webcon, that markets Webers and intakes. They listed a 3x2 Weber set up for the Y Block using an Edelbrock 573. The K9124 kit has since been discontinued on their current website.
http://www.webcon.co.uk/weber/USPerformanceKits.htm
John Mummert
Posted 15 Years Ago
Mark, found this picture of 3-2 set-up with DCNF Webers. Okay, its a scrub intake but you get the idea.
JAM Engineering makes all kinds of carb adapters
MarkMontereyBay
Posted 15 Years Ago
John,
That is a clean looking setup. I have been searching for a couple of days online for some DCNF carbs without luck. Seems they are obsolete, or unobtainable for some reason. I found that EMPI is apparently making some kind of copy but saw lots of negative stuff about them. I need to get some dimensions (vertical) in order to deal with hood clearance on my Bird to see if this a workable alternative. Any leads on DCNF's? Is there another Weber model that would work?
JAM Engineering turns out to be in Monterey. I gave them a call. Maybe they can get me up to speed.BigGrin
