You can guarantee Pat, that I will be asking about some things...I know that engines are primarily a glorified air pump, but the y is its own beast, and I am still learning the stuff to use. I believe I can reach the goal I have set with it, pretty conservative I think. My 57 has a lot of Crites body parts plus an ancient set if AI glass fenders, so it should come in pretty light, I'm aiming for around 3300-3400 lbs or so, preferrably less, but I'm trying to be realistic. I want to be able to run low 13s with it, so about 300-325 hp should get me close, with a good set of slicks. My 57 should be in paint this summer some time, then I'll get it wired plumbed and fired up. I hope to get the upholstery done over the winter. Should be identical to Dunc's old 57Custom, Colonial white with gray inside. I had planned on red inside, and still may do that, but gray is just more simple, maybe easier to keep looking new too...
Plan to use around 10.5 or 11:1 compression...is that too much for non-posted G heads or should I just loom for some 113s? I plan to use probe pistons and the aftetmarket rods in the 312...the 292 will just be a temporary runner, mostly stock, maybe a cruiser (lumpy) cam, but the 312 I want to be a brute. I make no bones about how much Wally's 56 has impressed me...that car is awesome....
James Potter
`57 Fords International
`57 Custom Tudor
`57 Fords International National Director
Pass Christian, MS (near Gulfport/Biloxi)
