Big6ft6
Visits: 347
oldcarmark (5/29/2011) As far as getting brake shoes I could have given you the part#s required.The shoes are available but most places dont have catalogs that go back far enough.Same with wheel cylinders.They are the same cylinders used on mid to late 60's Mustangs.It would be a very good idea to get replacement return and holdown spring kits.After all these years they get weak.You're right Old car, I will get some new springs, but the stores in town had to order the "Kit" as they didn't carry it in stock. I've done two drum brake jobs before this one and they were both rear drum/front disc cars. This is the first time I've had real drum brake tools! What a difference! That little tool for un-hooking the re-turn springs makes it a snap! So it'll be easy to replace the springs when I get a set. Back in high school (in 1997) I had 69 marquis convertible I was using pliers and screw drivers to get the springs off and on, what a pain!
Nate - Madison, Wisconsin 56 Ford Customline Sedan
Big6ft6
Visits: 347
oldcarmark (5/29/2011) As far as getting brake shoes I could have given you the part#s required.The shoes are available but most places dont have catalogs that go back far enough.Same with wheel cylinders.They are the same cylinders used on mid to late 60's Mustangs.It would be a very good idea to get replacement return and holdown spring kits.After all these years they get weak.Oldcar, they are the same wheel cylinders? Man oh man! They have 68 mustang wheel cylinders in stock at my local store (I just looked)! They have a different part numbers than what I got for the 56, but they sure look the same in the picture. Are they exactly the same or are they "also fit" parts? Jeez, that would've saved me a ton of time to know that this past Friday.
GREENBIRD56
Visits: 102.7K
Like they say - welcome to the club.......its amazing the things you find out about this "restoration" process as you go along. Those rear wheel cylinders - from the Mustangs - come in several different bore sizes (as was necessary to change the application force as the drums got sized larger). Often the sizes are listed in the Mustang restoration parts catalogs - and due to their popularity the Mustang parts are often way easier to access. The little ponies had 14 inch wheels and 15 inch wheels - and 1.75 width drums and 2.00 width drums - and a lot of hardware along the way. One bit of wisdom I can relate though - keep a record of the part numbers, or model and type of vehicle you are pirating your parts from. My cheat sheets are now usually stuck in the back of my trusty shop manual and without them, it would be hard to negotiate with the commercial parts computers that are not loaded with the same quality of information
Steve Metzger Tucson, Arizona
Visits: 323.8K
Nate: Some later Fords had shoes that are for 11 1/32 diameter drums instead of 11". All other aspects of the shoes are identical except maybe the hole for the hold down springs. Later holes are a little larger because of the self adjusting mechanism. Anyway, if your drums have never been turned, the 11 1/32 shoes will not fit the drums. Maybe that is what your problem is. Turning the drums and arcing the shoes will fix it. Early '55s also had cam adjusters in addition to the lower adjusting screw. Does yours have these, one for each shoe? Have you backed them off to their minimum setting? These adjusters are just above the hold down springs, have an 11/16" headed bolt on the outside of the backing plate for adjusting them.
Big6ft6
Visits: 347
Hoosier Hurricane (5/30/2011)
Nate: Some later Fords had shoes that are for 11 1/32 diameter drums instead of 11". All other aspects of the shoes are identical except maybe the hole for the hold down springs. Later holes are a little larger because of the self adjusting mechanism. Anyway, if your drums have never been turned, the 11 1/32 shoes will not fit the drums. Maybe that is what your problem is. Turning the drums and arcing the shoes will fix it. Early '55s also had cam adjusters in addition to the lower adjusting screw. Does yours have these, one for each shoe? Have you backed them off to their minimum setting? These adjusters are just above the hold down springs, have an 11/16" headed bolt on the outside of the backing plate for adjusting them. Hey Hoosier, I don't have any "cams" that I could tell. The brake set-up was pretty simple, two return springs, and one spring above the adjusting screw. Not much in the backing plate excpet holes for the little hold-down spring pins and the little rubber access plug for the adjusting screw. I used part number 228 for shoes from Checker/O'Reilly's Autoparts. They are listed as 11 x 2.07 inches. The shoes that were on the car measured about 2.25 inches wide so these were slightly narrower.
Frankenstein57
Visits: 891
One thing I always made sure to grind off the ridge on the edge of the drum, if your shoes are slightly wider they could be riding on the ridge. Every time I tried to have drums turned they said sorry, to thin. Either they didn't want to do it, or to sell new ones.  :
thanks, Mark
roy culp
Last Active: 15 Years Ago
Visits: 11
check width of brake shoes, compare to shoes removed Roy che check width of brake shoes
Big6ft6
Visits: 347
The new shoes are slightly narrower by about 0.15"
Big6ft6
Visits: 347
Just an update for future readers who might find this thread and need to find a drum-turning shop. I called a garage near my office, they were concerned that the front drum with the intgegral hub might not fit on their machine, I asked about a machine shop on the area that would be able to do it, and they said try the parts store down the street, they have a full machine shop. So I called down there and sure enough he said "no problem" could have it done in an hour! He just asked that I take my bearings and oil seal out of the hub. It is literally a block down the street from office!!  (small sucesses keep me going!) Will that be a problem to pull the oil seal out? Are they a pain to replace, I see another local parts store has the seals in stock, do I just tap it in flush with the rim of the inside of the drum?
Visits: 323.8K
Nate: What I usually do is take the castellated nut off, rock the hub enough to get the outer bearing and washer off, put the nut back on a couple of threads, and pull the drum off slide hammer style. The seal and inner bearing will pop right out. The bearing outer races do not need to be removed to turn the drums. Clean and pack the bearings with grease, tap the new seal in flush, and you're good to go.
