By Big6ft6 - 15 Years Ago
I redid my front brakes today my 56 Customline, and after re-mounting the front drums/hubs it is so tight I cannot turn it by hand. What is wierd is that I can slide the drum onto the spindle over the shoes without much effort, it is a snug fit, but not hard to get the drum on. However I cannot turn the drum by hand once it is in position. The adjuster nut is tightened into it's smallest position, and I hardly have the banjo nut tightened at all. Even with the wheel/tire mounted I cannot turn the wheel by hand. Is this happening just because I have brand new pads that are probably touching the drum? Is this bad? It is just suprising me beucase it wasn'too hard mounting the drum over the shoes, snug, but not hard to get the drum on.
By Grizzly - 15 Years Ago
Nate, Can you define "redid my brakes" have your replaced shoes, wheel cylinder, had your hubs off? What did you do? Hubs should turn with wheels on with minimal resistance, only a little brake drag once adjusted. If you cannot move your hubs you've done something wrong. Don't be afraid of asking how before you try something. You'll waste a lot of time and money doing thing the opposite way. cheers Warren
By Rono - 15 Years Ago
Nate; Did you have the drums turned at a shop? Usually if you bring them the new shoes when you bring them the drums, they make sue there is no binding. Sounds like either the drums need to be turned or the brake shoes need to be arched so they are matched. Rono
Grizzly, I replaced the wheel cylinder and shoes. I also cleaned up the backing plate, I reused the return springs, and original wheel bearing, etc. Then I just cleaned the drum really well with brake parts cleaner (since it originally had brake fluid spilled in it). Rono, I did not have the drums turned I was hoping I wouldn't need to do that. last time I needed drums turned I called a few places and I couldn't find anyone to do it, but that was years ago maybe I didn't try hard enough. Do most brake service centers turn drums? Even though I theoretically know better, I just hope that the new shoes will clean up the drum surface after a few stops. Maybe that is the issue, even though they feel pretty smooth, maybe the drum surface is too rough, it allows me to slide the drum over the shoes, but too rough to rotate.
Big6ft6 (5/29/2011)Do most brakeservice centers turn drums?
Many newer vehicles use rear drums so I would think so but I would not be surprised if today's replace rather than repair culture could have made turning obsolete.
There's a machine shop in my town that offers that service so it is still done at at least a few places.
Did you make sure that the shoes were the same before installing? Incorrect shoes can cause brakes to drag. Over 50+ years it's nearly impossible to know what's been done to a car. It's possible that the correct shoes may not be the needed shoes.
Big, you should have the drums turned, the new show will not "clean them up". Besides if your drum is out of round it will cause binding.
After turning you should have the shoes re-arched to the new drum diameter.
Jeez, if I have to find a machine shop to turn the drums this is going to be a never-ending brake project. I'll spare you the horror stories about getting the correct shoes from the local parts stores, but I will say I spent far more time driving around town than working on the car yesterday. I finally got shoes that I think are correct, they are very slightly narrower than the ones that were on the car, but otherwise are identical. I'm also taking this opportunity to convert to the 68 Bronco dual master cylinder, so I was "customizing" new brake line routes yesterday as well. I'll have to wait until Tuesday to see if I can find a shop that still turns drums, but I'm worried it will be a ghost chase. The car has only 30k miles on it, and the drums seem to be in good shape, the shoes I took were basically new (still had clean stickers on them) but were probably installed 30 years ago when my uncle was driving it in the 70's, I had to take them out becuase the wheel cylinder let go and soaked everything in brake fluid otherwise they were in great shape.
By oldcarmark - 15 Years Ago
As far as getting brake shoes I could have given you the part#s required.The shoes are available but most places dont have catalogs that go back far enough.Same with wheel cylinders.They are the same cylinders used on mid to late 60's Mustangs.It would be a very good idea to get replacement return and holdown spring kits.After all these years they get weak.
Big6ft6 (5/29/2011)
Jeez, if I have to find a machine shop to turn the drums this is going to be a never-ending brake project. I'll spare you the horror stories about getting the correct shoes from the local parts stores, but I will say I spent far more time driving around town than working on the car yesterday. I finally got shoes that I think are correct, they are very slightly narrower than the ones that were on the car, but otherwise are identical. I'm also taking this opportunity to convert to the 68 Bronco dual master cylinder, so I was "customizing" new brake line routes yesterday as well. Nate, welcome to car restoration. If it was easy everyone would be doing it. I'll ditto the "take your drums and shoes and get the drums machined and the shoes arced". A good brake place would have relined your old shoes at fraction of the cost of new. Did your hubs turn freely before you installed the drums? Cheers Warren
Grizzly, you're right older cars present unique challenges, but I seem to experience the same phenomenon whether I'm installing a closet organizer for my wife, or repairing my 99 escort, I spend more time driving around than actually doing the project! Some of it is unavoidable as a DIYer, but some is inexcusable. The most recent phenomenon is that you can find parts on the part-store website, and even determine of they have the part in stock at the store in your neighborhood. However when you get to the store, the staff at the store don't have acess to the same data that is on the website so unless I brought the part number with me, they can't always find the same part on the computers in the store!! I had to drive back home to look up the part number on the company's OWN webiste, then drive back to the store and give them the part number so they can give me the part! There is no excuse for that. The brake shoes are only $20 for two sets (both front wheels), do places really still re-line the shoes for less than that? I'll do some research on Tuesday to try and find a place to turn the drums, I took them both off now so I can take them in with the shoes and have it all "done up" properly. I can't wait to drive around again, and it will be a different experience with confidence in my brakes!
oldcarmark (5/29/2011) As far as getting brake shoes I could have given you the part#s required.The shoes are available but most places dont have catalogs that go back far enough.Same with wheel cylinders.They are the same cylinders used on mid to late 60's Mustangs.It would be a very good idea to get replacement return and holdown spring kits.After all these years they get weak.You're right Old car, I will get some new springs, but the stores in town had to order the "Kit" as they didn't carry it in stock. I've done two drum brake jobs before this one and they were both rear drum/front disc cars. This is the first time I've had real drum brake tools! What a difference! That little tool for un-hooking the re-turn springs makes it a snap! So it'll be easy to replace the springs when I get a set. Back in high school (in 1997) I had 69 marquis convertible I was using pliers and screw drivers to get the springs off and on, what a pain!
oldcarmark (5/29/2011) As far as getting brake shoes I could have given you the part#s required.The shoes are available but most places dont have catalogs that go back far enough.Same with wheel cylinders.They are the same cylinders used on mid to late 60's Mustangs.It would be a very good idea to get replacement return and holdown spring kits.After all these years they get weak.Oldcar, they are the same wheel cylinders? Man oh man! They have 68 mustang wheel cylinders in stock at my local store (I just looked)! They have a different part numbers than what I got for the 56, but they sure look the same in the picture. Are they exactly the same or are they "also fit" parts? Jeez, that would've saved me a ton of time to know that this past Friday.
By GREENBIRD56 - 15 Years Ago
Like they say - welcome to the club.......its amazing the things you find out about this "restoration" process as you go along. Those rear wheel cylinders - from the Mustangs - come in several different bore sizes (as was necessary to change the application force as the drums got sized larger). Often the sizes are listed in the Mustang restoration parts catalogs - and due to their popularity the Mustang parts are often way easier to access. The little ponies had 14 inch wheels and 15 inch wheels - and 1.75 width drums and 2.00 width drums - and a lot of hardware along the way. One bit of wisdom I can relate though - keep a record of the part numbers, or model and type of vehicle you are pirating your parts from. My cheat sheets are now usually stuck in the back of my trusty shop manual and without them, it would be hard to negotiate with the commercial parts computers that are not loaded with the same quality of information
Nate: Some later Fords had shoes that are for 11 1/32 diameter drums instead of 11". All other aspects of the shoes are identical except maybe the hole for the hold down springs. Later holes are a little larger because of the self adjusting mechanism. Anyway, if your drums have never been turned, the 11 1/32 shoes will not fit the drums. Maybe that is what your problem is. Turning the drums and arcing the shoes will fix it. Early '55s also had cam adjusters in addition to the lower adjusting screw. Does yours have these, one for each shoe? Have you backed them off to their minimum setting? These adjusters are just above the hold down springs, have an 11/16" headed bolt on the outside of the backing plate for adjusting them.
Hoosier Hurricane (5/30/2011)
Nate: Some later Fords had shoes that are for 11 1/32 diameter drums instead of 11". All other aspects of the shoes are identical except maybe the hole for the hold down springs. Later holes are a little larger because of the self adjusting mechanism. Anyway, if your drums have never been turned, the 11 1/32 shoes will not fit the drums. Maybe that is what your problem is. Turning the drums and arcing the shoes will fix it. Early '55s also had cam adjusters in addition to the lower adjusting screw. Does yours have these, one for each shoe? Have you backed them off to their minimum setting? These adjusters are just above the hold down springs, have an 11/16" headed bolt on the outside of the backing plate for adjusting them. Hey Hoosier, I don't have any "cams" that I could tell. The brake set-up was pretty simple, two return springs, and one spring above the adjusting screw. Not much in the backing plate excpet holes for the little hold-down spring pins and the little rubber access plug for the adjusting screw. I used part number 228 for shoes from Checker/O'Reilly's Autoparts. They are listed as 11 x 2.07 inches. The shoes that were on the car measured about 2.25 inches wide so these were slightly narrower.
By Frankenstein57 - 15 Years Ago
One thing I always made sure to grind off the ridge on the edge of the drum, if your shoes are slightly wider they could be riding on the ridge. Every time I tried to have drums turned they said sorry, to thin. Either they didn't want to do it, or to sell new ones. :
By roy culp - 15 Years Ago
check width of brake shoes, compare to shoes removed Roy che check width of brake shoes
The new shoes are slightly narrower by about 0.15"
Just an update for future readers who might find this thread and need to find a drum-turning shop. I called a garage near my office, they were concerned that the front drum with the intgegral hub might not fit on their machine, I asked about a machine shop on the area that would be able to do it, and they said try the parts store down the street, they have a full machine shop. So I called down there and sure enough he said "no problem" could have it done in an hour! He just asked that I take my bearings and oil seal out of the hub. It is literally a block down the street from office!! (small sucesses keep me going!)Will that be a problem to pull the oil seal out? Are they a pain to replace, I see another local parts store has the seals in stock, do I just tap it in flush with the rim of the inside of the drum?
Nate: What I usually do is take the castellated nut off, rock the hub enough to get the outer bearing and washer off, put the nut back on a couple of threads, and pull the drum off slide hammer style. The seal and inner bearing will pop right out. The bearing outer races do not need to be removed to turn the drums. Clean and pack the bearings with grease, tap the new seal in flush, and you're good to go.
By glrbird - 15 Years Ago
With old cars is all about perseverance. If you ask enough questions you will get put in the right direction. Always look for the oldest guy in the shop to talk to.
Nate, As you are re-doing your brakes I'd be replacing bearings and seals as a matter of course. (unless you are on a really tight budget). You shouldn't have to be back in there for a while. Bearings are not that expensive. Just a thought do you know how to adjust front wheel bearings?? Cheers Warren
By dbzach64C - 15 Years Ago
After reading these comments I can now see why I buy many parts from folks like Dennis Carpenter and Concours Parts. When you order a set of plug wires or brakes shoes from them for a 56 Vicky...that's what you get. Many of the local parts places don't have a clue. I get tired of the "We can get it but it'll come out of the warehouse in KC." Yeah you gotta pay shipping but it's worth it to me.
Hoosier Hurricane (6/1/2011)
Nate: What I usually do is take the castellated nut off, rock the hub enough to get the outer bearing and washer off, put the nut back on a couple of threads, and pull the drum off slide hammer style. The seal and inner bearing will pop right out. The bearing outer races do not need to be removed to turn the drums. Clean and pack the bearings with grease, tap the new seal in flush, and you're good to go. Awesome! Thanks John! Those are the tips that make my day!
Grizzly (6/1/2011)
Nate, As you are re-doing your brakes I'd be replacing bearings and seals as a matter of course. (unless you are on a really tight budget). You shouldn't have to be back in there for a while. Bearings are not that expensive. Just a thought do you know how to adjust front wheel bearings?? Cheers Warren Yeah, I suppose you're right Warren I'll pick up new bearings/seals. I read about tightenening the castle nut in my repair manual, but I've never done it, it was darn loose when I took the drum off, not even finger tight. Is there any tricks?
Nate, Over tight wheel bearings can cause the problem of drag that you initially described. There are a dozen different methods of adjusting front wheel bearings. All are a little hard to understand because it's a "by feel" thing. Firstly the nut should be loose. A VW beetle that my ex owned called for a mic and an adjustment of 1 thou play at the edge of the disk. Which gives an indication of how they should be set. Grease and put your assembly together and hand tighten the nut until you cannot feel any play in the bearing by wiggling the hub drum. There should be about one notch (in the castlated nut) between noticeable play and none. This is where you want it, loose then one notch to remove play. Put your wheel on and while it still off the ground give the wheel a wriggle as you've probably seen mechanics do and give it a spin. Be sure your feeling just the play in the bearing checking what is moving. There should be little to no play and just the slightest rolling resistance by hand. In use the bearing will expand with heat (friction) and give you your loading. Too tight and you'll damage the bearing too loose and you'll damage the bearing. Don't be afraid to do it several times to get the feel. When you are happy put you split pin in and the cap back on. Cheers Warren
Well, I had my drums turned at that solved the drag issue. So I now have a fairly new brake system, 68 bronco MC, new hoses up front, new front wheels cylinders, new pads. All new lines up front, I have a new line coming off the MC and I joined it to some of the existing rear line. I haven't done anything to the back brakes, I plan to, but time and budget didn't allow me to do them this weekend. There weren't any leaks or problems out back so I thought I could probably at least drive around the block again with now that I have a new dual master, and all new front brakes. So I went to bleed my new brake system, and I can't get a firm pedal. I followed the instructions for bleeding the master, and had a rock hard pedal with the master and the bleeding plugs. But then when I hooked up my lines and bled all four wheel cylinders, I ended up with a very soft pedal. I had good fluid flow at each wheel cylinder, I bled it until I had no bubbles. I don'tk now what the deal is. I do have a small drip leak where the new rear line coming off the MC joins the existing line, but it doesn't seem that small leak should be accounting for my pedal being able to go down to the floor with all the bleeder valves closed?? Especially with a dual MC you'd think of the front brake circuit was tight and leak free, that I'd at least get pedal resistance from the fronts? Any ideas? Would a leak in the rear brake circuit account for the soft pedal? I was wondering maybe the way the Master Cylinder is built, the first circuit to be pressurized during pedal travel is the rear cirucuit, and since there is a leak in the rear that is why I have so much pdeal travel. And that I wouldn't feel the front pressure until I had almost gotten to the end of the pedal stroke, any truth to that theory? I have the MC hooked up correctly, rear circuit to the front port etc. and I put a washer in the push rod opening to take up that extra slack from the 68 MC.
By aussiebill - 15 Years Ago
MoonShadow (6/1/2011) There have been problems with the cup size on push rods. Some push rods sold as Y-Block are not. The cups are a little smaller and the ball on the rocker arm does not fit down in the cup far enough. As a result the ball rides high on the upper edges of the cup and the cups can break out. Usually the sides break. If thats how yours are broken then you need to check your push rods for fit. The ball should set well down into the cup. You still need to check the installation of the rocker shaft for oil flow. Hope this helps. Chuck inChuck you,re 100 percent right with p/rod cup size problem. best regards bill.
Nate: You did adjust the brakes after turning the drums, didn't you?
Yeah, I did, whether or not I did it good enough, I don't know. I was wondering so I went ahead and adjusted the front ones so that I couldn't move the wheel by hand just to see if changed the pedal feel. I did seem to give me a little firmer pedal but only way down at the end of the pedal travel. And that was with the front brakes adjusted so tight I couldn't rotate the drum by hand. The shop did not offer shoe "re-curving" so the shoes were not machined in any way to match the drum, but he said my drums were in good shape, he didn't have to do much but "clean 'em up", he said there was lots of metal left on the drums so I don't think they've been turned much, so I wouldn't think the drum would be much different in curvature than new pads?
Nate, Any leak in a brake system is just plain unaceptable. It's an accident waiting to happen. Besides just being rediculously dangerous you'll never sort your brakes out untill you fix the leak. I,ve never put a bronco master in a 55 but it sounds like your push rod is too short. If you put a washer in between the cup of the master and the ball of the push rod you've done the wrong thing. the ball and socket need to go together. look for a longer push rod or better still an adjustable one. Stop trying to take short cuts you need to be trying to do your best with every thing you do to the car. Things like brakes are safety items and you are not just endangering yourself but others. If it seems that you are doing something half arsed then stop and think. Ask before you tear off and do something stupid. It worrys me that some of these half arsed fixes are not being mentioned they only get aired once there is a further problem. How many more are there. Warren
By MoonShadow - 15 Years Ago
Easy Grizz he's learning as he goes and totaly open to advice. Sounds like the guy has no help available where he lives so he came to us. Good solid advice and suggestions but I'm not sure if the extra "emphasis" was necessary. Lets help this guy get on the road safely.
That said, no leaks in the brake system are acceptable except the seepage around the cap. Fix the leak then try to bleed again. Doe's the break pedal have play at the top of its stroke? Make sure you have the right length rod. Chuck
Grizzly, I appreciate your concern and safety always is number one, which is why I took this opportunity to upgrade to a dual master (68 bronco) so the two brake circuits are isolated and a leak in one ciruict wouldn't compromise the entire brake system. I hope I didn't give the wrong impression, The leak just occurred today where I joined the new line to the existing rear, so this isn't something I've been hiding until now. I haven't driven the car in this condition and I didn't intend to imply that a leaky line was an acceptable fix for any brake system. The nut in the cup on the master cylinder was something I got off of this site. http://www.y-blocksforever.com/forums/Topic30474-9-1.aspx I'm definitly not trying to do anything half-arsed or dangerous. I hope I haven't created the impression I don't take things seriously because that would probably lead to people not wanting to help me, and I really rely on all of you and enjoy the sense of coummunity. Sometimes when I post things I'm just sharing on the forum becuase I want to share with others who care about cars, at home the only person I have to talk with is my wife and she has about a 45 second attention span when it comes to be talking about my car problems. I fully intend to repair the leak before I go any further, but what has me confused is that the small leak that I see seems to be too small to account for the fluid that would normally be displaced with a full stroke of the brake pedal, which is what I'm able to do right now, so where is that fluid going? I had good flow at all four wheels while bleeding the brakes and no air bubbles. Is it possible that there is still air somewhere in the line even when no bubbles appear when bleeding?
Did you bench bleed the MC before installing it? If not that could be your problem. Also make sure all 4 brakes are adjusted. I understand the puzzlement about the split chamber MC but can't diagnose it from here. First thought is remove and bench bleed the MC and go from there.Chuck
MoonShadow (6/4/2011) Did you bench bleed the MC before installing it? If not that could be your problem. Also make sure all 4 brakes are adjusted. I understand the puzzlement about the split chamber MC but can't diagnose it from here. First thought is remove and bench bleed the MC and go from there.ChuckThanks Chuck I think that is a good idea, I'm going to start back at the beggining and bleed the MC again (after I fex the leak in the rear line). This MC came with bleding "plugs" instead of the dual hose bleeding kit I've seen before. The instructions say to screw these plastic plugs into the ports on the MC and then slowly stroke the master cylinder .75-1" max, until you have a firm pedal. Apparently the MC pushing aginst these plugs pushes the air back up into the bowls. When I converted my 71 to front power discs, the MC came with two little hoses and some nozzles that fit snuggly into the ports, and you just cycled fluid out the ports and back into the bowls. That systems seemed more intuitive than this bleeder "plug" system that came with the 68 bronco mc. But I was able to get a very firm pedal with the plastic plugs in the outlet ports, so this new method seemed to be working. Has anyone else used the plug-style MC bleeding before with sucess?
Big6ft6 (6/4/2011)
MoonShadow (6/4/2011) Did you bench bleed the MC before installing it? If not that could be your problem. Also make sure all 4 brakes are adjusted. I understand the puzzlement about the split chamber MC but can't diagnose it from here. First thought is remove and bench bleed the MC and go from there.ChuckThanks Chuck I think that is a good idea, I'm going to start back at the beggining and bleed the MC again (after I fex the leak in the rear line). This MC came with bleding "plugs" instead of the dual hose bleeding kit I've seen before. The instructions say to screw these plastic plugs into the ports on the MC and then slowly stroke the master cylinder .75-1" max, until you have a firm pedal. Apparently the MC pushing aginst these plugs pushes the air back up into the bowls. When I converted my 71 to front power discs, the MC came with two little hoses and some nozzles that fit snuggly into the ports, and you just cycled fluid out the ports and back into the bowls. That systems seemed more intuitive than this bleeder "plug" system that came with the 68 bronco mc. But I was able to get a very firm pedal with the plastic plugs in the outlet ports, so this new method seemed to be working. Has anyone else used the plug-style MC bleeding before with sucess? Nate, I,ve lost track of initial installation but is new M/Cyl bolted to front of inline booster? if so it is important as pointed out to (1) bench bleed M/Cyl on bench, old hands just use finger tips to lightly block holes allowing piston movement to push fluid and air out while quickly pushing fingers tighter over hole once done, VERY Important to avoid brake fluid in eyes or over car nearby, but works! (2) if bolted to a inline brake booster then adjust the little domed tip of booster pushrod to only slightly start pushing on back of M/C piston, not the pedal pushrod. If this IS your setup? follow these suggestions slowly step at a time and then give car light rebleed, plus readjust your shoes till they grab drum and back off only till the drum is free. This is usual timeproved method in my lifetime. good luck. regards bill. yyy
Thanks Bill, I do not have a booster (if you mean power brakes?) the push rod from the brake pedal is going straight into the cup on the master. The pushrod that came with the m.c. was 4 inches too long. The original pushrod did not have a ball on it, it only had what looked like a few threads (??) I looked inside my original m.c. to see if there appeared to be another piece that had come off in the cup, but didn't see anything. Is the original pushrod end supposed to be like that? Even after my drums were turned my drums don't "spin" freely when I put them on even before I tighten the spindle nut. They move pretty easily, but they definitly don't "spin". So the idea of expanding the adjuster until I feel "drag" and then backing of a few notches doesn't seem to work for me becuase the drag is there from the get go?
Thought I'd throw some pics up of my work so far.
Here I was pretty happy with how my tube bending for the one line that goes under the front cross member ended up lining up with in the correct location!
Big6ft6 (6/4/2011)
Nate, OK, so no booster, recheck your shoes it looks like you have both short leading shoes on that side, i.e short shoe to front of car, long shoe to rear. refit drums, lightly tighten bearing nut while spinning drum till finger tite, readjust shoes and then recheck pedal feel, you must have a little bit of freeplay between the m/cl piston and the pedal rod.
Thansk Bill! I was hoping you guys might catch something from the photos. It is funny, I when I was going through the hassle of finding the right brake shoes, the original set I had been given (wrong ones) I thought one shoe was had more material than the other. So when I went back to the parts store to get the correct shoes, I asked the person running the register at the parts store which way they go and he didn't know. So I turned around to the other people standing in line and asked out-loud if anyone knew which one went forward. Everyone kind of looked at eachother puzzled and finally one guy piped up in the at the next register "The shoe with more material goes foward, cuz that is where all the braking occurs". Everyone else nodded. However nobody seemed that confident, I don't think they had any more experience with drum brakes than I did, I think they guy was just guessing. However, when I got back to the garage, and I took out the new shoes, it appeared the shoes were all the same. I thought maybe I had been holding one shoe upside down or something before and that is why it looked like there were two different shoes. So I didn't think anything more of it. I'll get those straightened out, maybe that will loosen up the fit a little too so I have more room to adjust the brakes properly. Maybe when I re-bleed the MC I'll take that nut out of there to be sure the master cylinder has toom to completely re-turn to zero position. I'm pretty sure it does but I'm not positive, so it would be good to eliminate that variable.
By Ted - 15 Years Ago
Nate. As Aussie Bill mentions, the short shoes go to the front side. That’s simply because most braking does occur on the front shoes and putting the short shoes to the front equalizes the forces or pressure involved so that both the shoes brake equally.
This web illustration shows how the brakes are rigged for "self actuation". Be sure and use the "play " buttons and watch the movement. http://auto.howstuffworks.com/auto-parts/brakes/brake-types/drum-brake1.htm The leading shoe provides actuation power to the trailing shoe - the reason most drum brakes work so much better in "forward" than "reverse".
By yalincoln - 15 Years Ago
hi Nate, have you checked to see if the shoes both contact the centering pin on top? mabey the new wheel cyl. are too long and not letting the shoes seat against the top pin. also you can just set your shoes in the drum to see if they contact the drum in the middle of the shoe or if they contact at the ends. they should contact most of the way around. on wheel brgs. i usually tighten the nut with a pair if chanellock pliers. i spin the wheel and tighten the nut till it stops the wheel. i'll do this a couple times to seat the brgs. then i back it off till the wheel spins free, if the cotter pin doesn't line up i back the nut up till it does.
A suggestion on bench bleeding master.Take 2 short brake lines and bend them so they go back into the resovoir under the fluid level when the resovoir is filled with fluid.Work the piston back and forth slowly until no bubbles appear in the resovoir.To bleed the entire system by yourself start with longest line which should be right rear.Get a piece of rubber hose small enough to fit snug on the bleeder screw.Imerse the other end in a clean container(jar is good) with enough clean brake fluid that the hose end is in the fluid(cant suck air back in).Open the bleeder and pump brake pedal slowly several times.Helps if someone can watch container for air bubbles.4-5 pumps should do it.Make sure you keep resovoir filled.right rear,left rear,right front,left front.As you do each wheel close the bleeder.I am not sure what # brake shoes you got but my numbers are:R-263 front and B or R 55 rears.these numbers are universal industry numbers no matter who makes the shoes.As far as adjusting the shoes which you should do first-tighten the shoes until you cant turn the wheel.Dont jam it tight just enough that you cant turn it easily.Back off the adjuster 10 teeth on the adjiuster.Should put you in the ballpark.Slight drag when you turn the wheel by hand.
Thanks guys for all the tips, your responses have given me a little more energy go back downtown to where I keep the car and give it another go. I do know the shoes are tight against the top pin and I used the method the Oldcar describes for bleeding the system. In fact, it was the first time I appreciated the rust holes in the floor board, I was able to sit in the driver's seat and lean over and watch the clear bottle for air bubbles (at least for the fronts) while I was pressing the brake. With the rear I was able to stand outside the driver's door and stick my leg in to actuate the brakes while watching the bottle at the same time. I had good fluid flow at each wheel, I could see the fluid level rising in the clear bottle with each stroke of the brake pedal and could see there were no bubbles. I was really shocked after I finished bleeding to climb in the car and be able to slowly push the pedal all the way to the floor. It isn't floppy/loose there is resistance, but not much.
Thanks Greebird, that is a great animation. I never realized the whole shoe assembly shifted like that when braking, the leading shoe actually comes off the pin!
If you can slowly push it to the floor than you have a leak as you mentioned.If you overtighten the steel brake line fittings you can damage the flare which is why it leaks.The first reaction is to tighten them real tight.Moderation is better.
alright, well I re-bled the MC, took out the nut, ran new brake lines to the rear hose to get ride of the drip leak at the junction of the old and new lines. I switched the shoes around on my front drums to the shoes with less friction material is facing forward on both wheels. I re-bled the system and still very soft pedal. No fuild on the floor anywhere I can see.
Big6ft6 (6/5/2011)
alright, well I re-bled the MC, took out the nut, ran new brake lines to the rear hose to get ride of the drip leak at the junction of the old and new lines. I switched the shoes around on my front drums to the shoes with less friction material is facing forward on both wheels. I re-bled the system and still very soft pedal. No fuild on the floor anywhere I can see. Nate, why not try a cautious drive around your area, allowing time and distance to pull up behind traffic, only continue if it feels safe to do so, then readjust all the brakes and note if pedal pressure feels better. regards bill.
Bill I'm too nervous at this point to drive, the pedal slowly goes all the way the floor. Just like before, when I adjusted the front brakes pretty tight I did get a little more firmness at the very end (3 inches from the pedal hitting the floor) but just a little improvement. I also think one of my two new wheel cylinders might be leaking. When I was switching the pads around to correct my mis-installation. I noticed what looks like a small amount of brake fluid running down the backing plate on the front driver's side. this is a brand new wheel cylinder, so this would be very frustrating if it is leaking but I'm afraid it might be. Speaking of wheel cylinders what should I do with the old ones? There was no core charge when I bought my new ones. It seems a shame to throw this in the recycling bin. I also need to look more closely at the rear brakes again now that I've gained so much knowledge on how these brakes are supposed to be set up. I'm wondering if way back when I first pulled the rear drums off somehow one of the wheel cylinder rods came off the shoe or something. Something just isn't right, the fluid is going somewhere when I push on the pedal. It is either leaking insde a rear drum brake and not come out on the floor yet, or something is expanding that isn't supposed to be (or both). It just drives me crazy that only get an hour or two and then I'm called home, so I don't get a chance to look into everything. Now I'm just left 8 miles from the car to hypothesize with my laptop. This is why I need this form as my therapy for when I can't actually go work on the car. On a positive note, I've taken the brakes apart so many times now, what used to be a dreaded gask I can almost do in my sleep in about 90 seconds!
Big6ft6 (6/5/2011)
Bill I'm too nervous at this point to drive, the pedal slowly goes all the way the floor. Just like before, when I adjusted the front brakes pretty tight I did get a little more firmness at the very end (3 inches from the pedal hitting the floor) but just a little improvement. I also think one of my two new wheel cylinders might be leaking. When I was switching the pads around to correct my mis-installation. I noticed what looks like a small amount of brake fluid running down the backing plate on the front driver's side. this is a brand new wheel cylinder, so this would be very frustrating if it is leaking but I'm afraid it might be. Speaking of wheel cylinders what should I do with the old ones? There was no core charge when I bought my new ones. It seems a shame to throw this in the recycling bin. I also need to look more closely at the rear brakes again now that I've gained so much knowledge on how these brakes are supposed to be set up. I'm wondering if way back when I first pulled the rear drums off somehow one of the wheel cylinder rods came off the shoe or something. Something just isn't right, the fluid is going somewhere when I push on the pedal. It is either leaking insde a rear drum brake and not come out on the floor yet, or something is expanding that isn't supposed to be (or both). It just drives me crazy that only get an hour or two and then I'm called home, so I don't get a chance to look into everything. Now I'm just left 8 miles from the car to hypothesize with my laptop. This is why I need this form as my therapy for when I can't actually go work on the car. On a positive note, I've taken the brakes apart so many times now, what used to be a dreaded gask I can almost do in my sleep in about 90 seconds! Nate, Go Back to square 1, inspect each brake assy,one at a time! and be sure every component is correct, installed properly, no leaks, refit drum and do next one. Could one of the wheel cyl rods not be located in brake shoe and is just moving back and forth, thus allowing poor pedal pressure? this is easy to do on rear shoes as the park brake spreader plate covers it. good luck.
By rgrove - 15 Years Ago
Hi nate,
While i am by no means a brake expert, my wife and i did do our car as a frame off restoration ourselves. Im in wauconda, il, up near fox lake, and what i think is probably a 2 hour or so drive away. My schedule over next few weeks is pretty nuts, but if you like we could try to find a saturday or sunday i can come up and help if you like. Alternately i can pm you my phone # as well. When we did our car, there was nobody around who had any experience to help iron out the details you are facing, so i understand the frustration.
Also, consider getting a motiv products speed bleeder. I dont know what kind of adapter you need for the bronco mc, but it has been a huge help on my car when i flush the brake fluid every 2 years...
Also, in the future, you can use the napa or similar website tto look up part nos and x ref for numbers from your local store. I eventually just ended up ordering almost everything through tee bird products, as i was always sure it would be the right part, and usually fairly priced. The wait for shipping offset the aggravation of wrong parts, etc. For months i would call them every monday or every other and place a parts order, and they always arrived by wed or thurs that week...just a thought.
Rlet me know if you want some help.
Ron.
rgrove (6/5/2011) Hi nate, While i am by no means a brake expert, my wife and i did do our car as a frame off restoration ourselves. Im in wauconda, il, up near fox lake, and what i think is probably a 2 hour or so drive away. My schedule over next few weeks is pretty nuts, but if you like we could try to find a saturday or sunday i can come up and help if you like. Alternately i can pm you my phone # as well. When we did our car, there was nobody around who had any experience to help iron out the details you are facing, so i understand the frustration. Also, consider getting a motiv products speed bleeder. I dont know what kind of adapter you need for the bronco mc, but it has been a huge help on my car when i flush the brake fluid every 2 years... Also, in the future, you can use the napa or similar website tto look up part nos and x ref for numbers from your local store. I eventually just ended up ordering almost everything through tee bird products, as i was always sure it would be the right part, and usually fairly priced. The wait for shipping offset the aggravation of wrong parts, etc. For months i would call them every monday or every other and place a parts order, and they always arrived by wed or thurs that week...just a thought. Rlet me know if you want some help. Ron.Ron, thats nice of you to offer nate some expeirenced help, i couldnt but help thinking if any members or viewers might be able to offer a hand. Bravo.
rgrove (6/5/2011) Hi nate, Rlet me know if you want some help. Ron.Ron, thanks a ton for the offer! That is very generous, and I might get to that point. Right now I just need more time for myself to be at the garage before I waste anyone elses. It really slows my progress when I can only get out to the car for a couple hours per week (or every other week). This last time I felt like I was so close, I knew my fronts brakes are sorted out and it occured to me while I was standing in the garage that it has to be something like a disconnected wheel cylinder rod in the rear brakes. But before I could take off the rear wheels to check, my wife called and said "I hope you're on your way home!". She said it in that tone of voice that I knew I'd better drop everything and driving like heck towards the homestead! (by the way, my wife is awesome...she lets me keep broken down old cars in the driveway and rent a remote garage to keep more old cars, she mows the lawn and makes great food, she is very patient with me so I'm not complaining! ) All my lines are replace and new with the exception of the two lines on the rear axle, I see no drips or leaks on the ground under the car. I get good fluid flow at each wheel when bleeding. But the pedal is so soft and almost goes to the floor after I'm done. It has to be something obvious like the rear wheel cylinder disconnected that bill mentions, now I can't wait to go check. I might try to sneak out tonight to go look!
Nate, I may have been a bit harsh before but we are dealing with your safety and learning off a internet forum is not the best way to learn. Ron, thanks for your offer I think some hands on mentoring is what Nate needs. Nate your brake system is under a lot of pressure. Leaks may not appear as drips on the ground clean. Check all the joints that you have made with clean hands look (touch) every joint and if there is any presence of brake fluid you have a leak and you will not be able to get full pressure. Leaks will require tightening with a flange nut spanner. Some of these joints will end up surprisingly tight. You may have to redo double flanges or replace lines If you get some pressure then it drops away you have a leak. Just a thought was your M/C new/second hand/reconditioned. Just because it's new doesn't mean it's right. You should have good flow at all wheels. What have you done to correct the length of your pushrod. A poorly adjusted pedal can give the feeling of spongy brakes. Remember the brake pedal leverage ratio, a lot of travel at the end could be only a few millimeters at the master. Do you get good pressure close to the floor? Cheers Warren
Nate: Your posts indicate you have not had the rear brakes apart. The actuating pin in the wiheel cylinder will not just jump out of an intact brake assembly. You have mentioned soft pedal, and also the pedal goes slowly to the floor when you hold pressure on it. Which is it? If it slowly goes to the floor, and no external leak, then the fluid is bypassing the pressure cup in the master cylinder.
By Daniel Jessup - 15 Years Ago
Nate,
Keep at it, you will figure it out.
This reminds me of a great story about my first "solo" brake job on my dad's 56 F100 years ago. I replaced the mc (single unit - pretty much what we had back then), wheel cylinders, brake shoes, hardware, turned drums, bearings, seals, etc. I adjusted everything and was satisfied that I had done a good job. No issues with the pedal...felt hard and resistance was quick. So, I took it for a spin before taking the 20 mile trip home. I touched the pedal....WHAM! she stopped on a dime and I locked up all 4 wheels just about. I was a pretty elated teenager as I drove home early that evening to show off to my dad.
Now mind you, during the 20 mile trip, I kept smelling a distinct odor that kept getting stronger and stronger. How I didn't notice the smoke is beyond me. Anyway, I pull into the driveway and park the truck. "Man, that pedal is tight!" I say to myself. As I get out of the truck and walk up to the front door of the house, I see that there is smoke (brake dust, et al) filling all 4 wheel wells of the truck. I took a closer look, and noticed how hot everything was. "uh, oh," I say to myself. I probably got them a little too tight.
About that time, my dad comes out of the house..."What in tarnation! Son, what in the world did you do? Look at your taillights!"
Sure enough, the fluid had gotten so hot that the back pressure to the master cylinder had actuated the brake pressure switch, and my brake lights were kept in the on position. Oh boy, fun days...come a long way since then.
By the way, Hoosier is right about the cam(s) on your backing plate. You do have them. At the top of the backing plate, where the return springs attach to the tit, you will find that in that exact location on the back of the backing plate there is a large nut (maybe 15/16", but don't quote me on that). Loosen the nut and you can actually move the entire deal so that you can adjust tight/loose.
Also, there should be an actual eccentric (round stud that has an off center position) You can also go to the other side of the backing plate to adjust this cam. Once you rotate this cam, you can see how your shoe will go out/in in relation to the axle. Obviously this does not look like much of an adjustment, but it will give you more contact area on the drum.
Do you have a shop manual yet? I would recommend you get one. They are only about $25 or so from most retailers, restoration parts suppliers, and sometimes I have seen them in digital form on ebay (nice to get a pdf file and just print it out, take it to the shop, don't ruin the book, you get the idea)
As nasty as the underside of your car is (we have all been there), you may have a leak somewhere that is shooting fluid up into crud that is sitting somewhere on the frame, rear axle, etc. But, if you had a leak, you should be able to see your brake fluid level drop dramatically after just a few pumps of the pedal. Otherwise, I would start with hoosier's advice.
keep us informed.
By snowcone - 15 Years Ago
Nate
I know this is a bit late now, but I read the whole thread and there was an easy fix for your original problem of the drum being tight on the new shoes that no one mentioned and you wouldn't have to get the drums machined.
Whenever you fit new shoes into a worn drum, you have to file a chamfer on both sides of the new shoes.
The reason for this is that the old shoes have worn into the the drums and there would have been a small lip on both the inner and outer sides of the drums.
The new shoes have square edges (see your photos) and these will not conform to the worn shoulders of the drums, so a simple chamfer with a file will allow the new shoes to sit into the worn section and not bind.
Cheers
Gary
