Oldmics
Visits: 78.1K
Dropped my third 312 crank off at my machinest today for evaluation. He told me that a customer had bumped into one of my my ECZ cranks that I had left him for inspection and it had fallen over and broken in two  It had not been inspected. I figure that there are two ways to look at this situation-either call it a loss and dont worry about it since it may have been ultimatly cracked and finally went OR it fell just so exact to do the damange to a good crank and I"m owed something. Wadduya think gang? Oldmics
Last Active: 3 Weeks Ago
Visits: 32.6K
What did the machinist say?
mctim64
Posts: 2.4K,
Visits: 5.0K
If it broke in two just by being knocked over it wasn't a very good crank to begin with.
aussiebill
Posts: 1.8K,
Visits: 11.4K
oldcarmark (5/23/2011) What did the machinist say?Usually if crank was cracked leading to it breaking then there should? be telltale shiney/dark areas where break occured? maybe not but at least have a look or get opinion, but was probably weak to break by falling over as tim mentions.
Posts: 3.3K,
Visits: 238.8K
You said the 3rd crank.. what happened to the other one?
Last Active: 7 hours ago
Posts: 7.5K,
Visits: 205.8K
I’ll agree with Tim in that if the crankshaft broke simply by falling over, it was already a problem in the making. When leaving parts at any machine shop, be sure to mark your parts before "dropping them" off to keep everyone ‘honest’.
The Master Cylinder
Visits: 6.2K
Ted, Is that a pun?? "Before dropping them off". Sorry, 6 in the morning... Ted (5/24/2011) When leaving parts at any machine shop, be sure to mark your parts before dropping them off to keep everyone ‘honest’.
Oldmics
Visits: 78.1K
Machinest said " I guess I owe you a crank". My thinking is like Tims in it probably was not a good piece to start with BUT it was left in his care for evaluation. The other one of the two is O.K. and being ground. It is my crank as I knew the markings.I will reinspect both pieces of it for flaws. I think it best to ascertain a value on a replacement crank and just have him knock that amount off my bill. Nice comment about "dropping the crank off"- It cracked me up (pun intended :w00t Thanks for the input. Oldmics
Visits: 38.4K
I think the machinist is being honest about it. Many would just say tough luck and talk about previous damage. Knocking off on the bill would be appropriate. Chuck
The Master Cylinder
Visits: 6.2K
Oldmics (5/24/2011) Machinest said " I guess I owe you a crank".
OldmicsAll joking aside, sounds like your machinist is a stand up guy, unfortunately not too many around these days.
