Large pattern 4V Intake - ECZ-9425-B
Posted By YBLOCKMERC 14 Years Ago
YBLOCKMERC
Posted 14 Years Ago
Last Active: 5 Months Ago
Posts: 194, Visits: 20.6K
No cracks, no welds, no rust, sealing surfaces in good shape. Ready to install and run (might want to paint to match your engine). $150 + shipping. Pictures available on request.
SOLD
Marc
'54 Merc ragtop
Pt Townsend, WA
      http://forums.y-blocksforever.com/uploads/images/e83cf74f-a3dc-4e1a-a928-8075.jpg
Posted 14 Years Ago
Marc: Is it a car version? I found out, the hard way, that (some?) truck versions don't have provision for choke heat..
YBLOCKMERC
Posted 14 Years Ago
Paul - I did not know that. Learned something new.
This must be a car version as it has a fitting for a choke tube on the crossover.
Marc
'54 Merc ragtop
Pt Townsend, WA
Posted 14 Years Ago
If you have a manifold with no provision for the the heat tube just use a kit to install the stove in the exhaust manifold.This is what Ford did at some point as a service repair replacement.I see the kits on Ebay quite often.Just runs a heat tube in a sock  from the manifold up to the choke thermostat like the 60's 289-302 motors did.
Posted 14 Years Ago
Mark; Thanks, when looking for the kits, what are they called?. Choke stoves or ??.
gritsngumbo
Posted 14 Years Ago
Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)
Posts: 153, Visits: 2.2K
PF Arcand (5/21/2011)
Really? I didn't realize that ANY trucks had a 4 barrel carb.
Gerald Ingram aka "Gritsngumbo"
Monroe, LA
LITTLE RED: 64 Ford F100 Short Bed Styleside
BIG RED: 63 Ford F100 Long Bed Unibody
BBW RED: 61 Ford F100 BBW Long Bed Custom Cab Unibody
BIG “UN: 63 F250 Longbed Flareside
CREW CAB: 63 F100 "Stageway" Crew Cab w/Long "Wrong" Bed
Posted 14 Years Ago
Hi Paul.They are called choke conversion kits or choke kits.Next time I see one i will let you know.They come up every so often for about $10.00 or so.They are actually shown in the Ford parts catalogue as a "service replacement" for the choke tube setup in the intake manifold which as we know rusts out after a period of time.There was one on my car when I got it although now with the later Holley with electric choke i dont need it.
Posted 14 Years Ago
Thanks Mark. I'm wanting to use a Ford/Autolight 1.08 on my 4 Bbl intake installation. And since I'm in the Northern latitudes, a working choke would be nice. Don't know if an electric choke conversion was or is offered for that carb?.
Y block Billy
Posted 14 Years Ago
Posts: 1.6K, Visits: 5.2K
The truck 4bbl's were governed with matching distributor, they were a little rich and were governed at 3800rpm but the lowend torque from them was amazing.
55 Vicky & customline
Posted 14 Years Ago
Paul Arcand I sent a PM.If you dont get it let me know
