Large pattern 4V Intake - ECZ-9425-B
http://forums.y-blocksforever.com/Topic59032.aspx
By YBLOCKMERC - 14 Years Ago
No cracks, no welds, no rust, sealing surfaces in good shape. Ready to install and run (might want to paint to match your engine). $150 + shipping. Pictures available on request.
SOLD
By PF Arcand - 14 Years Ago
Marc: Is it a car version? I found out, the hard way, that (some?) truck versions don't have provision for choke heat..
Paul - I did not know that. Learned something new.
This must be a car version as it has a fitting for a choke tube on the crossover.
By oldcarmark - 14 Years Ago
If you have a manifold with no provision for the the heat tube just use a kit to install the stove in the exhaust manifold.This is what Ford did at some point as a service repair replacement.I see the kits on Ebay quite often.Just runs a heat tube in a sock  from the manifold up to the choke thermostat like the 60's 289-302 motors did.
Mark; Thanks, when looking for the kits, what are they called?. Choke stoves or ??.
By gritsngumbo - 14 Years Ago
PF Arcand (5/21/2011)
Really? I didn't realize that ANY trucks had a 4 barrel carb.
Hi Paul.They are called choke conversion kits or choke kits.Next time I see one i will let you know.They come up every so often for about $10.00 or so.They are actually shown in the Ford parts catalogue as a "service replacement" for the choke tube setup in the intake manifold which as we know rusts out after a period of time.There was one on my car when I got it although now with the later Holley with electric choke i dont need it.
Thanks Mark. I'm wanting to use a Ford/Autolight 1.08 on my 4 Bbl intake installation. And since I'm in the Northern latitudes, a working choke would be nice. Don't know if an electric choke conversion was or is offered for that carb?.
The truck 4bbl's were governed with matching distributor, they were a little rich and were governed at 3800rpm but the lowend torque from them was amazing.
Paul Arcand I sent a PM.If you dont get it let me know
