Macs1964F100
Visits: 177
Thank you again Ted. I will go with Ram Horns and 2 1/2 pipes necked in the way you did for the test. Work is slowing down and the weather is cooing off so I am ready to spend some time on the old truck.
By the way, the is Mac just North of San Antonio. I will stop by and thank you in person next time I am up your way.
Visits: 206.1K
A comment came up in another thread suggesting that the single exhaust crossover pipe system actually made better low-end torque than duals. Data from dyno testing does suggest otherwise. Here’s the graph displaying the torque values for the factory dual exhaust manifolds versus the single exhaust crossover system.
ejstith
Visits: 1.0K
I am sort of surprised that as good '57 stock manifolds are they haven't been reproduced into steel headers. Seems like someone with a tubing bender, electric hack saw & great welding ability would have done this. With the cost of swap meet & ebay manifolds being what they are I'd think they'd sell like hotcakes if they were in the $200-$250 range.
E.J. in Havana FL
Visits: 206.1K
ejstith (12/8/2013) I am sort of surprised that as good '57 stock manifolds are they haven't been reproduced into steel headers. Seems like someone with a tubing bender, electric hack saw & great welding ability would have done this. With the cost of swap meet & ebay manifolds being what they are I'd think they'd sell like hotcakes if they were in the $200-$250 range.Reds makes two different sets of headers for the ’54-’56 cars. The one tube variety is listed at $220 while the two tube variety is listed at $295. Here’s the link to a chart comparing some of the various exhaust manifolds and tubing headers. The headers that are simply a bolt-in replacement for the cast iron dual exhaust manifolds do not typically give much if any power boost over the cast iron exhaust manifolds. http://forums.y-blocksforever.com/FindPost58704.aspx
ejstith
Visits: 1.0K
Ted, you mentioned, in the test, Fenton cast iron manifolds. What is the deal on those? I assume they are rare as hen's teeth..
E.J. in Havana FL
Visits: 206.1K
ejstith (12/19/2013) Ted, you mentioned, in the test, Fenton cast iron manifolds. What is the deal on those? I assume they are rare as hen's teeth.. The Fenton manifolds have not been available for a good number of years now. There was a move recently to have them cast overseas but still waiting to hear more about that. For now, the manifolds seem to be relegated to ‘collector’ status as those people that have them, seem to have more than one set.
vntgtrk
Visits: 144
I'll admit I chose the aftermarket ram horns for my truck after seeing how they stacked up to the other configurations. While I don't have the induction or head mods, they will be a good choice for a street truck being built to haul a 2500 lb trailer on a regular basis. I looks I'll be making up an exhaust using mostly Hearthrob bits.
And yes I agree that this is valuable info. Heck this whole site has steered this novice in the right direction
CK and his 55Tbird
Visits: 273
Ted,
Have you or will you be testing Mummerts T-Bird headers?
Do you have any expectations of what results may occur?
Chris
Visits: 206.1K
CK and his 55Tbird (1/26/2014) Ted, Have you or will you be testing Mummerts T-Bird headers? Do you have any expectations of what results may occur? ChrisWhile I haven’t specifically tested a set of headers that came directly from John, there’s a chance they have been already tested depending upon who his supplier is. Here’s a couple of links showing pictures of some of the various headers and exhausts that have been tested thus far which can be used to compare some of the various designs against each other. .
http://forums.y-blocksforever.com/Topic55379.aspx?PageIndex=3 . http://forums.y-blocksforever.com/FindPost55795.aspx . And here is the chart again showing the ‘best’ score for each exhaust system tested thus far. Keep in mind that the best score does not necessarily produce the best peak horsepower or peak torque values. | Description. | Score | Peak HP | Peak TQ | Avg HP | Avg TQ | Mufflers | Testing configs | | Single exhaust with crossover pipe | 1484 | 239 | 303 | 202 | 276 | NO | 2 | | 1955/56 Dual Exhaust manifolds | 1629 | 274 | 327 | 223 | 301 | NO | 4 | | Reds/Hedman two tube headers | 1635 | 278 | 327 | 224 | 302 | NO | 3 | | 1957 Dual Exhaust manifolds | 1650 | 279 | 330 | 226 | 305 | NO | 4 | | Fenton cast iron manifolds | 1663 | 282 | 332 | 228 | 308 | NO | 2 | | Tri-Y stepped shorty Tbird headers non-firing order specific - GB | 1675 | 294 | 332 | 230 | 309 | NO | 4 | | Ram Horns w/2”into 2¼” pipes | 1683 | 283 | 337 | 230 | 312 | NO | 2 | | Shorty 1.625” w/box collectors - DC | 1693 | 284 | 336 | 231 | 314 | NO | 1 | | JC 4 tube car chassis shorty headers | 1739 | 296 | 347 | 238 | 322 | NO | 6 | | Tri-Y pickup headers firing order specific-CC | 1739 | 297 | 347 | 238 | 322 | NO | 5 | | Sanderson 1½” T-Bird headers w/2½” pipes | 1751 | 297 | 350 | 240 | 324 | NO | 11 | | Sanderson 1½” Pickup headers w/2½” pipes | 1751 | 300 | 350 | 240 | 324 | NO | 5 | | Reds 1.625” 4 tube hdrs for 55/56 car | 1753 | 295 | 347 | 240 | 325 | NO | 8 | | Fenderwell headers 1.75” tubes - MW | 1768 | 306 | 344 | 242 | 327 | NO | 5 | | Fenderwell headers 1.625” tubes | 1769 | 308 | 346 | 243 | 327 | NO | 5 | | KC 4 tube Maxton Mile 1 5/8” headers | 1775 | 310 | 351 | 244 | 328 | NO | 4 | | Rdstr 4 tube 1.75” gattling collector hdr | 1778 | 309 | 355 | 244 | 329 | NO | 2 | | EMC headers 1.75”/1.875” stepped | 1780 | 310 | 349 | 244 | 329 | YES | 4 | | FPA T-Bird hdrs 1.625”/1.75” stepped | 1780 | 311 | 342 | 244 | 329 | NO | 13 |
CK and his 55Tbird
Visits: 273
Thanks Ted. The FPA type are the ones I was thinking of.
I think I'll go for the Saunders shorty that I saw on Ebay for $250. Due to I will be using the car as a daily driver and from what you were saying about coated heaaders, stainless is a much better choice, and its only 10HP. I'll spend the extra on the intake.
