Last Active: 14 Years Ago
Visits: 11
I have for sale a 1956/57 Ford 312 short block(ECZ 6015C)that just came out of the I.D.M. Speed & Machine shop. It has been cleaned and magnafluxed, bored and honed 060 over, deck blocked and washed. The main caps read ECZ-6329-A. This motor is fresh and ready to be reassembled. Block comes with new after market I Beam Performance Rods, New Pistons and Rings(060)with less than 15 minutes run time on them, Used 312 crank in excellent condition and original 1956/57 312 Thunder Bird only Oil Pan in excellent condition. Call larry @ 609-548-8588 with any questions.
LDP
Visits: 1.4K
It would help to know where you are located....................
56 victoria
Visits: 1.2K
609 is New Jersey.
Warsaw, IN
Visits: 78.1K
Visits: 11
Located in NJ 08050
LDP
Posts: 7.4K,
Visits: 205.7K
tooleo (1/24/2011) ....... New Pistons and Rings(060)with less than 15 minutes run time on them........Larry. Can you explain why the pistons and rings have some run time on them?
Visits: 11
They were in my original 312 motor that I just had rebuilt 060. After I put the motor back in the car I noticed that the blocked was cracked so the motor had to be replaced. I purchased (2) excellent condition 312 blocks and put one in my car and the other is 4 sale.
LDP
Visits: 11
Can anyone tell me what the number 76L stamped on the block means?
LDP
Visits: 11
SOLD!!!!!
LDP
Posts: 7.4K,
Visits: 205.7K
tooleo (1/26/2011) Can anyone tell me what the number 76L stamped on the block means?Normally I’d think you were looking at a date code but date codes typically have a letter for the second digit whereas yours has a ‘6’. If that ‘76L’ is indeed the date code, it breaks down as June 11, 1957. Can you post a picture? Going to the top of the 'This N That' section will get you the instructions for picture posting.
