Lots of parts from a 1962 Unibody F-100
Posted By BIGREDTODD 15 Years Ago
Posted 15 Years Ago
Tim: Would you mind elaborating on the condition & so on, of the Distributor you mentioned?
mctim64
Posted 15 Years Ago
Posts: 2.4K, Visits: 5.0K
Todd, I want to keep the bell. Wink
There's a good dizzy in there though, sell it!
BIGREDTODD
Posted 15 Years Ago
Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)
Posts: 324, Visits: 2.4K
No body parts available, just mechanical or items listed below. The shell is the main thing being used, so if your curious about something, just ask.
Pretty unmolested original 292/3-speed combo. Keeping the long block, but everything else is up for grabs to fund the build. for instance:
  • OEM PCV set-up
  • Nice (no rust) battery tray
  • Original cross-over manifold set-up with functional heat riser and x-pipe
  • Stock 2bbl carb/manifold
  • Non-hydraulic clutch linkage
  • 3 speed (non-OD) transmission. Not original to truck, has a mounting boss on the tail shaft. Haven't pulled the numbers yet to see what it is.
Also getting rid of the original seat, in-cab gas tank, and lots of little doo-dads you may be looking for.
Basically, if you need something PM me and we can talk. Otherwise I will start gutting the thing out and listing on Ebay. I haven't started piecing the thing apart yet, but will probably start getting down to business this weekend.
Todd in Central California...about half way between Fresno and Sacramento
1956 Thunderbird - 1960 F-100 - 1961 Starliner - 1961 Imperial
