Lots of parts from a 1962 Unibody F-100
http://forums.y-blocksforever.com/Topic51496.aspx
By BIGREDTODD - 15 Years Ago
No body parts available, just mechanical or items listed below. The shell is the main thing being used, so if your curious about something, just ask.
Pretty unmolested original 292/3-speed combo. Keeping the long block, but everything else is up for grabs to fund the build. for instance:
  • OEM PCV set-up
  • Nice (no rust) battery tray
  • Original cross-over manifold set-up with functional heat riser and x-pipe
  • Stock 2bbl carb/manifold
  • Non-hydraulic clutch linkage
  • 3 speed (non-OD) transmission. Not original to truck, has a mounting boss on the tail shaft. Haven't pulled the numbers yet to see what it is.
Also getting rid of the original seat, in-cab gas tank, and lots of little doo-dads you may be looking for.
Basically, if you need something PM me and we can talk. Otherwise I will start gutting the thing out and listing on Ebay. I haven't started piecing the thing apart yet, but will probably start getting down to business this weekend.
By mctim64 - 15 Years Ago
Todd, I want to keep the bell. Wink
There's a good dizzy in there though, sell it!
By PF Arcand - 15 Years Ago
Tim: Would you mind elaborating on the condition & so on, of the Distributor you mentioned?
