Pwr. Steering Brackets 272
Posted By NM56F100 15 Years Ago
NM56F100
Posted 15 Years Ago
Last Active: 14 Years Ago
Posts: 12, Visits: 22
Anyone have a line on power steering pump brackets for a 272 (ECG).  Mommert has one for the GM Saginaw pump.  And one for what he calls "an original Eaton" pump.  I don't know what on original Eaton is.  Perhaps a vintage Ford pump used on t birds or something and he wasn't sure.
Anyhow, I am hooking up a Mustang power rack and pinion from Heidts and need a lead on brackets for a pump that would be appropriate.  Heigts doesn't seem to know.
NM56F100
Posted 15 Years Ago
Sorry, forgot to say the Saginaw is a high flow pump I think.
Posted 15 Years Ago
Last Active: 14 hours ago
Posts: 4.6K, Visits: 38.4K
The Eaton pump was used on the Y-block and FE's well into the 60's. The tank and mounts may change but the basic pump is the same. I believe that they will be fine with the Mustang rack and pinion. By going that way you just need the stock brackets for your Y-Block and a set of hoses that fit from the pump to the rack. Could even be the same connectors. There are shops around that make up hydraulic hoses that can make one up for you if needed. Chuck in NH
55vickey
Posted 15 Years Ago
Supercharged (455 reputation)Supercharged (455 reputation)Supercharged (455 reputation)Supercharged (455 reputation)Supercharged (455 reputation)Supercharged (455 reputation)Supercharged (455 reputation)Supercharged (455 reputation)Supercharged (455 reputation)
Posts: 396, Visits: 6.4K
I have a '57 Eaton power steering pump, tank, and all the brackets if you're interested. I would imagine the pump would have to be rebuilt. Gary
Gary, 55 Vicky, St. Germain, Wisconsin
labamba2
Posted 15 Years Ago
First Time Poster
First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)
Last Active: 15 Years Ago
Posts: 1, Visits: 2
i would like to know if your brackets have ford numbers on them thanks richard
55vickey
Posted 15 Years Ago
The only bracket that has a # is the one to the water pump......ECG-33559-A
gritsngumbo
Posted 15 Years Ago
Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)
Posts: 153, Visits: 2.2K
55vickey (10/11/2010)
Gary: If Richard isn't interested in your PS setup, I might be depending on price. PM me if he doesn't want it. Thanks.
Gerald Ingram aka "Gritsngumbo"
Monroe, LA
LITTLE RED: 64 Ford F100 Short Bed Styleside
BIG RED: 63 Ford F100 Long Bed Unibody
BBW RED: 61 Ford F100 BBW Long Bed Custom Cab Unibody
BIG “UN: 63 F250 Longbed Flareside
CREW CAB: 63 F100 "Stageway" Crew Cab w/Long "Wrong" Bed
55vickey
Posted 15 Years Ago
Hey gritsngumbo, delete some of your message box, it won't let me get thru to you, Gary
gritsngumbo
Posted 15 Years Ago
Sorry, I've cleared it out some, Thanks.
Monroe, LA
55vickey
Posted 15 Years Ago
Says you're still to full, Gary
