Pwr. Steering Brackets 272
http://forums.y-blocksforever.com/Topic50687.aspx
By NM56F100 - 15 Years Ago
Anyone have a line on power steering pump brackets for a 272 (ECG).  Mommert has one for the GM Saginaw pump.  And one for what he calls "an original Eaton" pump.  I don't know what on original Eaton is.  Perhaps a vintage Ford pump used on t birds or something and he wasn't sure.
Anyhow, I am hooking up a Mustang power rack and pinion from Heidts and need a lead on brackets for a pump that would be appropriate.  Heigts doesn't seem to know.
Sorry, forgot to say the Saginaw is a high flow pump I think.
By MoonShadow - 15 Years Ago
The Eaton pump was used on the Y-block and FE's well into the 60's. The tank and mounts may change but the basic pump is the same. I believe that they will be fine with the Mustang rack and pinion. By going that way you just need the stock brackets for your Y-Block and a set of hoses that fit from the pump to the rack. Could even be the same connectors. There are shops around that make up hydraulic hoses that can make one up for you if needed. Chuck in NH
By 55vickey - 15 Years Ago
I have a '57 Eaton power steering pump, tank, and all the brackets if you're interested. I would imagine the pump would have to be rebuilt. Gary
By labamba2 - 15 Years Ago
i would like to know if your brackets have ford numbers on them thanks richard
The only bracket that has a # is the one to the water pump......ECG-33559-A
By gritsngumbo - 15 Years Ago
55vickey (10/11/2010)
Gary: If Richard isn't interested in your PS setup, I might be depending on price. PM me if he doesn't want it. Thanks.
Hey gritsngumbo, delete some of your message box, it won't let me get thru to you, Gary
Sorry, I've cleared it out some, Thanks.
Says you're still to full, Gary
By PF Arcand - 15 Years Ago
I've tried in the past to clear some stuff out of my PM box in the past, without success. Don't know why it does not work. It seems that "computer geeks" go out of their way to make the procedures difficult..
By DonZ - 15 Years Ago
Did you sell the parts for the Power Steering?
By pegleg - 15 Years Ago
just as a matter of info, Mummert is re-making the power steering brackets for the original pumps
