Original dual-quad setup on Ebay
Posted By oldcarmark 15 Years Ago
Posted 15 Years Ago
Theres an interesting setup on Ebay.Item 110584346738.Interesting but BIG bucks too.Is this what they go for?Correction-should item# 110584346788
Bob's 55
Posted 15 Years Ago
Posts: 287, Visits: 1.0K
OldMark, That #110584346738 does not take you to a dual quad manifold
BOB
Posted 15 Years Ago
Sorry! Should be 110584346788 not 38 last 2 numbers.
Nick Brann
Posted 15 Years Ago
Supercharged (166 reputation)Supercharged (166 reputation)Supercharged (166 reputation)Supercharged (166 reputation)Supercharged (166 reputation)Supercharged (166 reputation)Supercharged (166 reputation)Supercharged (166 reputation)Supercharged (166 reputation)
Posts: 166, Visits: 1.9K
Hi Mark,  If he had the correct original carburetors then that would be a fair price, in my opinion.  It doesn't sound like he does.  Also needed is the special valley pan regardless of whether it is going on a T-Bird or passenger car.  The carbs are the most expensive part of the setup, and the air cleaners are expensive also.  It looks like he has the passenger car air filter which is too tall to fit on a T-Bird, FYI.  The manifolds are readily available most of the time.  Thanks for the heads up, Nick Brann - K.C., MO
Posted 15 Years Ago
If you need the valley pan and the regular 4bbl intake does not need the special pan,wonder why he didnt take the special pan off when he switched intakes.
