Original dual-quad setup on Ebay
http://forums.y-blocksforever.com/Topic49582.aspx
By oldcarmark - 15 Years Ago
Theres an interesting setup on Ebay.Item 110584346738.Interesting but BIG bucks too.Is this what they go for?Correction-should item# 110584346788
By Bob's 55 - 15 Years Ago
OldMark, That #110584346738 does not take you to a dual quad manifold
Sorry! Should be 110584346788 not 38 last 2 numbers.
By Nick Brann - 15 Years Ago
Hi Mark,  If he had the correct original carburetors then that would be a fair price, in my opinion.  It doesn't sound like he does.  Also needed is the special valley pan regardless of whether it is going on a T-Bird or passenger car.  The carbs are the most expensive part of the setup, and the air cleaners are expensive also.  It looks like he has the passenger car air filter which is too tall to fit on a T-Bird, FYI.  The manifolds are readily available most of the time.  Thanks for the heads up, Nick Brann - K.C., MO
If you need the valley pan and the regular 4bbl intake does not need the special pan,wonder why he didnt take the special pan off when he switched intakes.
