Getting ready for Bonneville Speedweek.
Posted By mctim64 15 Years Ago
mctim64
Posted 15 Years Ago
Posts: 2.4K, Visits: 5.0K
Sorry to say after all that work as good as the headers looked they did not work. w00t  I guess I didn't take into consideration the position of the strait axle after being lowered. Tongue  Back to the drawing board.
Posted 15 Years Ago
Posts: 6.1K, Visits: 442.8K
I was wondering about that but I figured you had everything scoped out. What if you put them on upside down and stick them through the hood?
JJ
Posted 15 Years Ago
Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)
Posts: 28, Visits: 485
Will they work on your truck?Wink
Glen Henderson
Posted 15 Years Ago
Posts: 1.4K, Visits: 7.5K
Tim, I had mine on and off at least twenty times during the build and they still don't fit just like I want them too but I'm still tweeking on them. Not a step for a stepper, I'm sure that you will get it worked out and good luck at the "flats".
Glen Henderson
Freedom is not Free
Letohatchee, AL
mctim64
Posted 15 Years Ago
charliemccraney (8/1/2010)
Funny! Tongue
mctim64
Posted 15 Years Ago
JJ (8/1/2010)
Just might, I'm not going to through them away.
Glen, I guess I was too smart for my own good.  I didn't have the truck where I was putting them together but thought I had it all figured out, they fit very well if the truck was taller or I just took the axle out they would work.  Believe me there was a lot of thinking going on when I found my mistake, the best we came up with for time and budget was to use the old exhaust with different collectors (3").  It's a big disappointment and I feel pretty stupid but that's just one of lifes lessons learned. Rolleyes
aussiebill
Posted 15 Years Ago
Posts: 1.8K, Visits: 11.4K
mctim64 (8/1/2010)
JJ (8/1/2010)
IIt's a big disappointment and I feel pretty stupid but that's just one of lifes lessons learned. Rolleyes
Tim, welcome! join the rest of us!Tongue
yyy
 Down Under, Australia
Posted 15 Years Ago
mctim64 (8/1/2010)
Well, if you decide to throw them away, I'll take'em.Wink
Try this. Jack the truck so the the axle hangs, unbolt the front or rear of the springs to let them hang even farther, if necessary. Install the headers. Let if down real fast. The axle will make it's own clearance. Fire it up and drive real fast, 125 - 130mph or so, over a good sized speed bump. That will provide any additional clearance required for the full compression of the suspension.
Glen Henderson
Posted 15 Years Ago
Charlie, I think you are just trying to make Tim mad enough that he will tell you to take the headers and see if you can make them fit! Sneaky, sneaky!
Glen Henderson
Freedom is not Free
Letohatchee, AL
mctim64
Posted 15 Years Ago
That just might work! I think I'll give it a try. BigGrin  NOT!Tongue
