She's alive!
Posted By charliemccraney 18 Years Ago
Posted 18 Years Ago
She started up tonight at about 8:30.  It is sweet!  Absolutely worth the many, many hours of work!
The Y sounds absolutely wicked with the X-pipe and glass packs!  The torque is amazing.  I'd like to get it on a chassis dyno to see what I have.  3rd gear cruising down the road and it will take off!
Thanks to all who offered advice and insight relating to this project.
LON
Posted 18 Years Ago
Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)
Posts: 523, Visits: 3.7K
Congratulations!!!! That looks great ,but I'm sure it sounds even better ??? When do we get to hear it running ??? I love the wild X -pipe .
WE WANT SOUND !!!
Regards Lon
yblocksdownunder
Posted 18 Years Ago
I'll see if I can get a hold of a decent sound recorder.  I would like to get some video.  I don't want to buy a camcorder just for that though.
It will have to wait for a week or so.  I have to get new rocker arms.  The old ones aren't holding the adjustment very well.  I've put about 30 miles on it.  The plugs are bone white.  So it looks like I will be able to find some more power as I tune it.  It hasn't done any knocking though.  Timing is at about 10 initial and 35 total.
Posted 17 Years Ago
I made a video, primarily to record the sound, while it was warming up this morning.
The glass packs have been swapped for Hooker Aero Chamber mufflers but it still sounds good!
http://www.youtube.com/watch?v=qnwVX2uWE4Q
Couldn't rev it - Too early in the morning.
63 Red Stake Bed
Posted 17 Years Ago
Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)
Last Active: 14 Years Ago
Posts: 193, Visits: 594
Sounds & looks fantastic!  Maybe a ride-along video next???
What heads did you end up with?  Any other specs you willing to share?
Posted 17 Years Ago
Sure! There are no machining secrets or anything in this motor. I did check clearances and I know where everything is.
It is a 318 stroker kit from Mummert. The heads are street ported G's with 1.6:1 Dove roller rockers. Compression is some where between 9.4 and 9.6. The cam has .295 lift, 226@.050, 274 advertised, 112 lobe separation and installed about 2.5 degrees retarded. The headers are Red's stubbies, 1 1/2" primaries and 2.5" collector. The exhaust is 2.5" from the headers to the outlets which dump just in front of the axle. The carb is an Edelbrock 600 with a K&N filter, housing, and stub stack. The intake is Blue Thunder. I think that is all of the important specs.
yehaabill
Posted 17 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
Y-Guy: I'm jealous!!!!! Thats a rightous ride man.
           While admiring everything, I have a question. What is the
            mastercylinder from? (I'm about to tackle that job soon.)
                                       Thx Bill
Bill
Pelham,Al
Posted 17 Years Ago
The master cylinder is a corvette unit.  I think 1968ish.  I made a mounting plate to mount it.  It's about the same as the stock ford plate. The bolt spacing is a little wider on the chevy mc.
63 Red Stake Bed
Posted 17 Years Ago
Thanks Charlie.  2/5 Degrees Retarted?  Was the s/c cam built with alot of advance or something?   I think I read that Hoosier H. sets his back a degree or two...
John F
Posted 17 Years Ago
Supercharged (163 reputation)Supercharged (163 reputation)Supercharged (163 reputation)Supercharged (163 reputation)Supercharged (163 reputation)Supercharged (163 reputation)Supercharged (163 reputation)Supercharged (163 reputation)Supercharged (163 reputation)
Posts: 128, Visits: 2.6K
Hey charlie, it looks great! I'll bet it sounds as sweet as it looks. I'm looking forward to seeing it run at the shootout. Keep us all posted.
John F Smile
Ballwin, MO
http://www.y-blocksforever.com/forums/Uploads/Photos/6c460c4f-3e7d-48ff-8f97-617f.jpg
