Carb opinions - Trying to figure out the next one to try
Posted By rgrove 16 Years Ago
rgrove
Posted 16 Years Ago
Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)
Posts: 498, Visits: 3.5K
Called Jegs tech again.  This guy recommended the 465 as being more than adequate, even with my cam.  Indicated that Id have to play with secondary springs due to lower vac, but it should work fine with some tuning.  I think thats the one Ill order and see how it goes.
I do want to say THANKS to everyone who chimed in.  I honestly cant tell you how much I appreciate your thoughts and input; thanks again!!!!!
Ron Grove
Wauconda, IL
IowaJoe
Posted 16 Years Ago
First Time Poster
First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)
Last Active: 14 Years Ago
Posts: 1, Visits: 6
My carb of choice for the Y-block is the Autolite 4100 spread-bore built by Pony Carbs. They will set it up for your driving conditions. It has worked flawlessly on my 57 Custom 300 for many years. Check out their website.
Posted 16 Years Ago
Posts: 3.7K, Visits: 323.8K
I question the Jegs tech guy's knowledge of carburetor operation.  He said secondary springs may have to be juggled due to the lower vacuum because of the cam.  The secondary operation is not based on manifold vacuum, but venturi vacuum.  The secondaries open when venturi vacuum in the primaries indicate the need for more throttle opening.  Just my 2 cants.
rgrove
Posted 16 Years Ago
Hoosier Hurricane (8/4/2010)
To be fair John, I may have misquoted him.  He certainly said i may have to mess with the secondary springs to control timing of secondary opening, but he may have only been referring to it in relation to the weight of the car, cam peak rpm range, etc.  I may have misheard him relating it back to manifold vacuum.
Thanks!
Ron Grove
Wauconda, IL
