how on earth do you get the starter in????
Posted By rgrove 16 Years Ago
rgrove
Posted 16 Years Ago
Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)
Posts: 498, Visits: 3.5K
Hey john, no worries! Its funny because even in the shop manual there is a big warning aboutt the bendix locking, and they pretty much say you are sol if the pins drop!
So starter and new solenoid are in. Starter sounds a little rough due to poor alignment, presumably due to 2 bolts..tried loosening and readjusting a few times with limited success...
On other question though....while cranking, I disconnected the coil lead from solenoid, and it still started. Should that be, or is it further evidence of a bad ign sw?
Thanks to all!
Ron Grove
Wauconda, IL
Bob's 55
Posted 16 Years Ago
Posts: 287, Visits: 1.0K
rgrove (5/29/2010)
Ron, No it should not have started. I'd say something is connected incorrect or ignition switch.
I was going to ask if you had a "one wire" alternator and to check for feed back, but then it would not have shut off. That happened to me, what fun... Finally pulled the fuse to the fuel pump and let it run out of gas.
BOB
rgrove
Posted 16 Years Ago
ok, false alarm.  I tried it a few more times, and its lighting off as the key goes to the "on' position and the engine is still spinning down after the starter is shut off.  Ignition isnt hitting while the key is in the crank position and the coil wire is disconnected from solenoid....
Ron Grove
Wauconda, IL
Posted 16 Years Ago
Ron: I don't necessarily have a solution to installing the starter, but the noise mentioned reminds me of something Ted has posted on. Are you by chance using a later F.E. (352, 361, 390) starter? The early ones up to 1964 will fit, but '65 & later have a different Bendix drive setup which does not work properly with the "Y" flywheel. Just asking?
junkyardjeff
Posted 16 Years Ago
Last Active: 5 Months Ago
Posts: 813, Visits: 3.4K
I dont remember having too much problems removing the starter on my 55 when it still had the 272,since it was a sunliner I had to remove the complete trans when I resealed it but thats been over 15 years ago and plenty of beers since then so I might be forgetting something.
rgrove
Posted 16 Years Ago
Ok guys, figured Id give an update.  Initially I figured id take the care to my buddies shop for the top bolt, but at about 3 am I had another idea.  Here is what I did (in hopes it can help someone else in the future)
The problem was getting the ear on the starter to align with the hole in the trans...it was just barely off, so the bolt just couldnt get started.  So I bought a 5/16-18 threaded rod, and cut it to about 9", and double nutted the end to create a way to turn it.
Then I loosened the 2 bolts on the starter so the starter could dlide back about 3/4" or so, and fished the 9" long threaded rod over the top of the starter, and through the ear on the starter.  There was enough play with the lower bolts loose to move the starter around to get the threaded rod started in the upper hole, and I screwed it in using the jammed nuts on the end.
The rod now acted as a guide pin of sorts.  I thightened up the the other 2 bolts, unscrewed the threaded rod, and now the upper bolt started right in.  also, it became easier to use a 1/4" drive ratchet & extension, as it gave a little more room to wiggle around the block...
With the 3rd bolt in, (and tightened first), starter now works/sounds just fine!
Thanks for all of the help guys; I truly appreciate it.  hopefully this can help someone else in the future!
Ron Grove
Wauconda, IL
Phordric
Posted 16 Years Ago
First Time Poster
Last Active: 16 Years Ago
Posts: 4, Visits: 11
I know this is a really late addition to this question,but just felt I had to add my solution as I too spent way too much time unsuccessfully trying to get the bolts back in and tightened.I cut a hole big enough to get my hands in the footwell from the interior of the passenger side to access the back side of the starter.To seal and waterproof the hole I cut a larger piece of sheetmetal and drilled holes all the way around the perimeter and used the new piece as a template to drill matching holes around the perimeter of the hole in the footwell.I don't know what the technical name for them is but I went to ACE hardware and got nuts attached to a gripping clip that slip over the holes to hold the nut in place.I then put sealant between the new cover and base and put the short machine screws in before the sealant set up.Now the next time,and we all know there will be a next time,the starter needs replacing it should be a piece of cake.
Phordric
'55 Customline 2Door Post
'66 F100 ShortWide
