Oil pump leaks
Posted By PF Arcand 15 Years Ago
Posted 15 Years Ago
Recently installed pump leaks, mostly from the cover plate. Opened it up, the O ring looks o.k. but thought to replace it. However, it appears not to be a regular one, but a flat sided O ring. Am I correct? I'm presuming it's not recommended to use sealer on the plate perimeter, so are these O rings available? I have part #s for the pump attachment gasket & pickup tube to pump seal, but not for the O ring. Any help appreciated, thanks- Paul
aussiebill
Posted 15 Years Ago
Posts: 1.8K, Visits: 11.4K
PF Arcand (5/11/2010)
Paul, generally that o ring is left over in many engine rebuild gasket sets as most pumps are gear rotor type, i have lots of them, surely someone there may have one in old kit? just a thought!
 Down Under, Australia
rick55
Posted 15 Years Ago
Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)
Posts: 550, Visits: 4.4K
The oil pump seal Part Number:6619A is available from Tee Bird Products for $1.20.
Regards
Rick - West Australia
Posted 15 Years Ago
Last Active: 3 Weeks Ago
Paul! Sent you a PM.Did you get it?
Posted 15 Years Ago
Mark: I sent you an e mail from the site, but it is apparently in a que?? Not sure what's happening with that? I will check back later. Thanks
Posted 15 Years Ago
Paul-Try me direct .ima56fordguy@hotmail.com
Posted 15 Years Ago
Melling #K-56 for the rebuild kit for a gerotor oil pump.  These are still readily available.  The gerotor pumps use an 'o' ring while the spur gear pumps use a gasket.  The spur gear oil pumps are still available as a complette new unit.
Posted 15 Years Ago
Old Car Mark: Sorry for the delay contacting you. Have tried your e address twice. It comes back undeliverable. ??- Paul
Posted 15 Years Ago
Ted: thanks for the pump kit #. I'll check into it. - Paul
aussiebill
Posted 15 Years Ago
PF Arcand (5/14/2010)
paul, i have noticed this problem a lot, the message box i think only holds 20 messages and gets full easy, i hadnt noticed mine had 20, but once cleaned out appears to be ok? just  thought. regards bill.
