Wanted Throttle/Transmission linkage bellcrank
Posted By Marty 15 Years Ago
Marty
Posted 15 Years Ago
Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)Hitting on all eight cylinders (17 reputation)
Last Active: 15 Years Ago
Posts: 17, Visits: 29
I am having problems with the one one my 292, on occasion, need an extra one to tinker with to find a solution to why it occassionally slips.
Need to be like new.
Marty
Marty
Posted 15 Years Ago
Are you looking for the bellcrank for the 4bbl setup?They are hard to come by.Once in awhile they will show up on Ebay.
Marty
Posted 15 Years Ago
I replaced the 56 4V manifold with a 57 4V manifold and installed an Edlebrock 600.  It seem the balance spring is not balancing :-) or who knows what is happening.  Anyway sometimes it works as advertised and then sometimes when I try to accelerate nothing happend, weird.
I will check Ebay frequently.
Marty
Marty
Posted 15 Years Ago
Marty!The balancing spring?Is that the one on the bellcrank that keeps the 2 levers together(for want of a better description)?Same setup on mine but I went to a 390 Holey with the 57 manifold.If that lever is not working right you may have the spring in wrong holes.I had mine together wrong and it took me a few minutes to get the spring in properly.
