Posts: 1.0K,
Visits: 4.5K
Posts: 1.1K,
Visits: 58.8K
If you check on the old forums you can find more about heads and headwork tips. Also John Mummert's website explains the common things you need to know. Any used heads will most likely need overhaul and machining of some kind, it just depends on your wallet size as to what you want to achieve. I believe that good headwork is essential to a well performing engine as opposed to adding on things. In other words-Good heads and stock everything else is probably better than sticking on a bigger carb or headers. Of course most people don't do it this way since its not as easy or cost friendly. BUT if you do the heads as a primary thing- it will handle more easily what you throw at it Like Cam Carbs and Headers etc. Just my 2 cents.
Posts: 1.4K,
Visits: 7.5K
Any of the big valve heads are a good bet. The posted G heads are considered the best, but 113's are maybe easer to locate and all 113's are posted. If you are going to pay someone to work a set of heads, then it only makes sense to start with the best factory heads.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Posts: 3.3K,
Visits: 238.8K
Earl: First, you don't mention what heads you have on hand. ?. Also, what Tri Power manifold are you using? If it happens to be an Offenhauser, sell it to somebody who wants the look but isn't needing more performance. Offy's are a very poor internal design. A 4 barrel setup will out perform them easily.
