Wanted - High Compression Heads and 1.54 rockers or complete 292 in/around Brisbane, Australia!!
Posted By Whitey 15 Years Ago
Wanted - High Compression Heads and 1.54 rockers or complete 292...
Whitey
Posted 15 Years Ago
Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)
Last Active: 14 Years Ago
Posts: 37, Visits: 269
G'day All,
After some advice from Ted Eaton (thanks by the way) I'm seeking a rough idea of availability and cost to upgrade my 272 a bit and give her some more go.  Does anybody have a complete set of ECZ-G (non posted) heads and high ratio rockers for sale around SE Queensland and what is the going rate for such beauties?   My block is a standard 1955 CEBY 272 with what I think are ECG-B heads (bit rusty aroung the numbers).  She also has the original 1.43 rockers fitted as well.  The compression appears to be good, but will check on tues as I get a helper to assist turning her over, but there is no smoke at all and very happy to fire.
The other way to go is a complete 292 if available and whether the budget allows as I'm still sneaking the $$$ away from the Officer in Charge of Entertainment and Finances!  Will definately have alot of spendable $$ after August, but trying to find out my options still at the moment.
Cheers Whitey
My first V8!!
