G'day All, After some advice from Ted Eaton (thanks by the way) I'm seeking a rough idea of availability and cost to upgrade my 272 a bit and give her some more go. Does anybody have a complete set of ECZ-G (non posted) heads and high ratio rockers for sale around SE Queensland and what is the going rate for such beauties? My block is a standard 1955 CEBY 272 with what I think are ECG-B heads (bit rusty aroung the numbers). She also has the original 1.43 rockers fitted as well. The compression appears to be good, but will check on tues as I get a helper to assist turning her over, but there is no smoke at all and very happy to fire.
The other way to go is a complete 292 if available and whether the budget allows as I'm still sneaking the $$$ away from the Officer in Charge of Entertainment and Finances! Will definately have alot of spendable $$ after August, but trying to find out my options still at the moment.
Cheers Whitey
