Holley 94 or Stromberg 97 - Preferecnce?
Posted By gritsngumbo 16 Years Ago
gritsngumbo
Posted 16 Years Ago
Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)
Posts: 153, Visits: 2.2K
I guess it basically boils down to personal preference but would appreciate options of those who have tried both. I have a Edelbrock 557 on my stock 292 Y-Block. I currently have 97's installed* (which will all probably all will need to be rebuilt), but I have been reading a good bit recently about the Holley 94's as a more streetable/reliable replacement carb.
I like the nostalgia aspect of the 97's, but just wondered if (before I spend the money) getting a set of 94's would give me more reliability, less leakage, etc. Would appreciate you thoughts and shared experiences.
*Technically, the truck is currently running with what I believe is a Rochester carb in the center with the two outboard carbs disconnected but I have a rebuildable 97 available.
Gerald Ingram aka "Gritsngumbo"
Monroe, LA
LITTLE RED: 64 Ford F100 Short Bed Styleside
BIG RED: 63 Ford F100 Long Bed Unibody
BBW RED: 61 Ford F100 BBW Long Bed Custom Cab Unibody
BIG “UN: 63 F250 Longbed Flareside
CREW CAB: 63 F100 "Stageway" Crew Cab w/Long "Wrong" Bed
Posted 16 Years Ago
Last Active: 4 hours ago
Posts: 3.7K, Visits: 498.2K
The 94 is a better carb because it is more modern. 97's are nostalgia carbs and lots of guys go WOW!! when they see them. Rebuilding cost is probably about the same. I think the 94's, at least the later ones, have a higher cfm.
If you got the 97's, use them although if you sell them you can probably buy about ten 94's with the proceeds.
Bob's 55
Posted 16 Years Ago
Posts: 287, Visits: 1.0K
paul2748 (4/10/2010)
That is one of the most humorous reasons I have ever heard... hahahahaha, thanks for the laugh.
BOB
crenwelge
Posted 16 Years Ago
Posts: 512, Visits: 1.7K
I think the Strombergs are more for bragging rights. I like the Holley EBU and they are easy to find and easy to fix. I guess about every 55-56 272 had one so its easy to find matched ones. I even use them on my GMCs that have a 3 bolt manifold.
Kenneth
Fredricksburg, Texas
Philo
Posted 16 Years Ago
Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)
Last Active: 15 Years Ago
Posts: 60, Visits: 489
If you use the Strombergs, be sure to regulate your fuel pressure to 3 psi. or they WILL flood.
Also, with either one you have to consider which type of distributor your gonna use. i.e. Load-a-matic or '57 and up. The 'bergs have no provision for vacuum adv. and the 94's have to be modifided to work right with the late dist. (the center one only).
Triple carbs look cool, but a 4 barrel is the way to go! Wink
FIGHT CONFORMITY!
Bob's 55
Posted 16 Years Ago
Philo (4/11/2010)
Not true... Some Stromberg bases (although rare) had a ported vacuum port...
BOB
RB35
Posted 16 Years Ago
Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)Supercharged (78 reputation)
Posts: 48, Visits: 669
Swap meets have accessory vacuum plates, or use the manifold.  Also Edelbrock is about ready to reproduce the 94.  I also thing the 94 is a slightly better airflow cfm than the 97.
Selling the old '97's would make a good down payment on the new '97's, not the Speedway model.  The new ones are technically superior to the originals with a few of the internal issues fixed.
