Polishing an Engine
Posted By grovedawg 16 Years Ago
Hollow Head
Posted 16 Years Ago
Posts: 1.0K, Visits: 3.8K
Smile And when you are finished the outer side, you can crawl inside and keep working. That will lighten your block a bit too and it also helps the oil to flow back to oil pan. Is it worth doing? Absolutely, if it keeps you away of doing something more crazy... BigGrin. And if I would have to decide, just a layer of clear coat over the polished block.
grovedawg
Posted 16 Years Ago
Last Active: 14 Years Ago
Posts: 246, Visits: 622
Hollow Head (4/8/2010)
Smile And if I would have to decide, just a layer of clear coat over the polished block.
Can I do that? I LOVE the looks of raw metal, but didn't think that a clear coat would bond well enough to any type of metal without a primer- let a lone an engine block which will get REALLY hot.
Anyone have experience clear coating an enigne?
Heber City, UT (15 mins outside of Park City- basically it's in the mountains)
55 Effie
grovedawg
Posted 16 Years Ago
2188nrha (4/8/2010)
MY hat is off to you. I am almost finished do a set of finned aluminum valve covers I picked up on E Bay
Can not wait to see it when yo are done.
Throw some pics up of the polishing you're doing on those covers. I'd love to see them! (They're probably the same valve covers I was out-bid on last week Smile Ha ha ha!
55 Effie
Posted 16 Years Ago
grovedawg (4/8/2010)
[quote].
I cleared all of the aluminum parts on my engine. So far it's doing well. I have over 5000 miles on it.
grovedawg
Posted 16 Years Ago
Doug T (4/7/2010)
The 4 "blocks" along the out side of the head are likely to be part of the holding system for when the heads were machinedat the factory. These blocks are very useful to check if the heads have been milled. Unmilled stock heads should measure exactly 1.000" high. Less than that and the heads have been milled to the difference between the measured block thickness and 1.000"
Thanks for the heads up Doug! I'll go check the measurements to see where they're at! And I'll post some more pics as I progress.
55 Effie
grovedawg
Posted 16 Years Ago
So, I loved the Y block at the top and decided to paint mine gold. But I want some opinions 'cause I'm on my third brand of paint. I hated the Eastwood high temp oldsmobile gold. It looked like the color of my moms walls. NOT HOT ROD! So I bought two rattle cans of gold paint, the universal gold by duplicolor, and VHT metal flake gold.
What are you're opinions. Speak now or forever hold your peace. I really am torn between the two.
Duplicolor is the lighter gold on the left. VHT is the more "redish" gold on the right. Sorry I don't have a better pic. Smile
55 Effie
grovedawg
Posted 16 Years Ago
I'm actually kind of leaning more towards the VHT on the right. Any opinions are accepted. 'Cause in the end I'm the one who chooses and lives with it. Smile
55 Effie
YellowWing
Posted 16 Years Ago
Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)
Posts: 296, Visits: 1.8K
I think you should go with  the VHT and I'm never wrong, just ask my wife. Smile
1956 Fairlane Victoria (ORREO)
Overlooking Beautiful Rimrock AZ
danray63
Posted 16 Years Ago
Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)
Last Active: 16 Years Ago
Posts: 5, Visits: 17
If it was mine, I'd go for the left, but it's not. I just thought it would look sweet with aluminum valve covers. Well, just about everything else aluminum.
Butch Lawson
Posted 16 Years Ago
Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)
Posts: 235, Visits: 20.9K
I used the VHT universal gold on my engine and then cleared over it with a two part R-M Diamont clear.  The clear seems to have bonded very well with the VHT.  I think it turned out great and the clear should help to keep it looking clean longer.
Butch Lawson
Manchester,  TN
