"Y" block land speed record
Posted By machanist1 16 Years Ago
57FordPU
Posted 15 Years Ago
Posts: 726, Visits: 73.6K
Nice photoshop job.  Now you and Todd should show them the real thing!  You guys are doing some great work there and you should share it.
BurnsRacing981@gmail.com
yalincoln
Posted 15 Years Ago
Posts: 382, Visits: 4.9K
yes, that's great, what class are going for? can you use a bed cover or drop the tail gate for less drag. mabey even use the tail gate like a air foil to keep the rear hooked up better at speed.
     say charlie, are you alowed to run a bed cover that goes from the roof of the cab down to the tail gate since you GMC is modified?
 good luck to all, and happy new year.
57FordPU
Posted 15 Years Ago
Good question about the bed cover.  In modified, you can do some things different than in production, but not as much as you might think.  The bed cover rules for modified pickup are the same as production pickup.  You can cover the bed but no higher than the bed rails and the rules say that it can have no aerodynamic advantage.  You can run with the tailgate up, down or off.  I never thought of running the tail gate at 45* to give you some kind of spoiler or wing effect.  The bed cover is best, but if you felt you had enough run opportunities, you could do experimental runs?
Posted 15 Years Ago
Posts: 3.7K, Visits: 323.8K
I read or heard somewhere that wind tunnel testing of a pickup with the tailgate open and closed showed that the closed gate caused a large air bubble to be carried in the bed, and the moving air passed over it with little resistance.  Shot down the theory of running trucks at the drags with the gate down.  Of course, a lowered gate moved a little weight to the rear for traction help, and some gates were found to have added weight in them.
Posted 15 Years Ago
Posts: 4.6K, Visits: 39.5K
I think Mythbusters did a segment on the tailgate issue and found that it really made no difference for everyday driving. They didn't test drag or LSR. Chuck in NH
Posted 15 Years Ago
After further deliberation, it may have been Gordon Payne who told me about the testing, by Ford engineering, to evaluate fuel mileage, a big concern by the manufacturers with the government setting fuel economy goals.
