Light at the end of the tunnel...
Posted By BIGREDTODD 15 Years Ago
Posted 13 Years Ago
Todd-
Congratulations! I LIKE the velocity stacks!
Consider checking out So-Cal Speed Shop listing of stainless steel bug dome screens for your carbs. They're listed as fitting Stromberg, Holley, and Ford style 48, 81, 94, and 97 carbs. I think that they'll work with the stacks...
OTBGear makes 'em. -Part No. 4020.
So-Cals Part No. is OTBGR001060
Regards,
YBLOCKMERC
Posted 13 Years Ago
Last Active: 6 Months Ago
Posts: 194, Visits: 20.6K
Outstanding Todd! Kind of a shame to have to muffle that awesome rumble of an unrestricted Y exhaust.
Marc
'54 Merc ragtop
Pt Townsend, WA
      http://forums.y-blocksforever.com/uploads/images/e83cf74f-a3dc-4e1a-a928-8075.jpg
BIGREDTODD
Posted 13 Years Ago
Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)
Posts: 324, Visits: 2.4K
NoShortcuts (5/16/2012)
Todd-
Regards,
Thanks!
Look close, they're already installed! Got a few from SoCal Sacramento recently. For anyone considering these, they do need some massaging (on a 94 at least) to clear the vent tube, as well as the choke butterfly. They look cool though!
The velocity stacks are from Seller's Equipped, and I don't believe he makes them anymore. They are spun aluminum. I milled them down for hood clearance, then had them polished with the Edelbrock V/C's that aren't yet installed. I couldn't find any conventional air cleaner bodies that would clear my hood and look right with the whole package.
Todd in Central California...about half way between Fresno and Sacramento
1956 Thunderbird - 1960 F-100 - 1961 Starliner - 1961 Imperial
BIGREDTODD
Posted 13 Years Ago
YBLOCKMERC (5/16/2012)
Thanks, and I agree about the sound...sure was fun running around the neighborhood with open headers & down tubes! The kids that were on recess at the school up the street sure liked it (not sure about the teachers:w00tSmile
Should still have a nice exhaust note. 2" duals with 18" glass packs (installed backwards, to mitigate some of the "fluff") should fit the bill. Was planning on 2 1/4", but 2" was much more suited to the stock frame, hangers, etc. I am running the exhaust through simple turn downs at the rear bumper. The stock bumper exit deflectors make the exhaust sound really "farty" as it bounces around.
BIGREDTODD
Posted 13 Years Ago
Exhaust is done...2" duals with glass packs
http://www.youtube.com/watch?v=JNuiC4qVbRs&feature=youtu.be
BIGREDTODD
Posted 13 Years Ago
Well, I met my goal, made it to the Graffiti Night cruise in my home town of Modesto...car performed beautifully, just needs to be final tuned...
The finished engine compartment (I caught the fuel line clamp on the #1 carb: Smile
Here's me and the Bird "Audrey" at the cruise as captured by a local auto journalist:
I also had my sister's '62 Lincoln (which she got from Dad after he passed) gone over for her,  so we could park & cruise together...she was pretty happy...
Her '62 got a lot of attention, too...repainted in the original color...
The '56 to my left was still Y-block powered! A really nice car!
57FordPU
Posted 13 Years Ago
Posts: 726, Visits: 73.6K
Congrats Todd, the bird looks great.  Now all the hard work will pay off as you enjoy the cruises and shows.  Didn't know about the Lincoln, it's nice that your sister took an interest in that.  With the 61 they would make a great trio on the grass somewhere.  The cars are a nice way to honor your dad, he was a great man.
BurnsRacing981@gmail.com
MarkMontereyBay
Posted 13 Years Ago
Posts: 733, Visits: 3.8K
Todd,
That is a truly fine looking ride. The engine is beautiful. I am curious as to what fuel regulator and pressure you have it set at. Also, what brand of fuel pressure gauge you have mounted on the fuel log. I am using two of the end carbs I got from you plus another from the bunch I bought from Charlie Burns for the primary on my Bird. I sorted out the "push" throttle linkage so it works but want to revisit it with a better set of joints. I am not running a regulator at present using the stock 57 fuel pump. The gauge I have from Vintage Speed is unreliable. Runs good but has the chronic 94 problem of bleeding down after it sits for awhile. Thanks.
57 Black Tbird 312/auto
BIGREDTODD
Posted 13 Years Ago
Charlie, thanks for the kind words as always. Dad & I bought the Lincoln in 1987 (if I recall correctly) at the Turlock Swap Meet. I was 9 years old at the time, but still remember the test drive. The paint was dead, but the body was straight as an arrow and absolutely rust free. The intererior remains original, though showing age on the driver's seat, to this day. Dad gave the Lincoln to her (and I a '61 Imperial) years before he passed.
Mark, it took me a while to decide on the fuel line set-up. My goal was to keep the look simple & uncluttered, but reliable & as "period" appearing as possible. That being said, I took several liberties. From the pump to the filter/reg. ass'y I used a hard line that exits the pump with a 90º brass fitting identical to the factory pump inlet line fitting. The regulator & filter are from Speedway & have functioned beautifully thus far. As supplied the regulator was chrome, and the filter was polished. I fastened them together with a brass union, as they were both female pipe thread at the outlet/inlet. I then scuffed, primed, and painted them Ford red to match the engine so they'd blend in to the front of the engine. From there, rubber lines, brass nipples, and stainless constant-tension clamps were used. The fuel block is a reproduction piece from Edelbrock, and the gauge was purchased from Dick York at dickshotrodplace.com (who also built & restored my carbs). I deliberately set the initial advance on the retarded side. When I put it where it runs the best, the car wants to be driven FAST, and just explodes to hi rev's when the 3x2 is opened up. Not the best way to go about working the bugs out. So far I'm very happy with my Mallory Uni-lite. I did notice that it had a bunch of end play from the factory, so it will need to be shimmed. But very crisp, and far easier to start than the old W&H dual point.
The push linkage is a huge PITA. So much so that I used the old tripower rod between the factory acc. linkage and the primary carb. I couldn't make a new one work as well...
My carbs bleed down too. I don't know that there's much way around it. my rear carb seeped a bit when I fired it up again, but has since stopped, so the gaskets are hopefully getting reinvigorated. I think the stuff gas may be evaporating faster than ever also. The seeping was my fault. I ran the car a couple times, than took it all apart, and due to more pressing family issues it sat dormant for 1 1/2 years.
Geez, just realized I wrote a book here. Hope some of it helps someone...
mctim64
Posted 13 Years Ago
Posts: 2.4K, Visits: 5.0K
Thanks for the pictures Todd!  Looks like "Graffiti Night" was a success.  Glad you and your sister had a good time.  Don't worry about writing books, I liked reading about your engine. Smile
