WANTED- MASTER CYLINDER
Posted By layourman 15 Years Ago
layourman
Posted 15 Years Ago
Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)
Posts: 27, Visits: 84
57 Thunderbird Master cylinder in rebuildable condition, I need one with the correct casting numbers for a concourse car. Thanks.     Layourman
Posted 15 Years Ago
Last Active: 10 hours ago
Posts: 3.7K, Visits: 322.9K
Do you know what casting number you need?
layourman
Posted 15 Years Ago
John- thank you for the interest, I have two different sets of numbers that were used for the 57 thunderbird,  first, these numbers are on the inboard side of the cylinder,(that is- readable from the passenger side of the car), FAA2155A and it also reads 1" DIA. There are other numbers on the cylinder that vary according to the time of cast
On the other cylinder, the letters BB appear on the drivers side of the cylinder, their are other numbers above the BB that vary depending upon the casting date. These of course are raised numbers and letters. Got one?
        Richard
Posted 15 Years Ago
I'll take a look tomorrow.  Do you have a preference which number?  What do you consider "rebuildable"?  Pitted to the point it needs a stainless sleeve?  Some pits are inevitable.  Is the "correct" cap available from the T-Bird vendors?
layourman
Posted 15 Years Ago
Well I am not sure if the numbers and the BB are on the same master. I dont think so. any cylinder that fits this criteria will do.
the cap can be had as a reproduction, unless you have an original, I think the cap will  have the letters BB on it. Thanks
Posted 15 Years Ago
Took a look today.  Only found one, it has the FAA number on the RH side.  The bore is pitted some, may need a sleeve.  There is no cap on it.  You can have it for $10 plus shipping from east central IN.
layourman
Posted 15 Years Ago
John-you say the master has the FAA2155A number on the inboard side,(passenger) what does it have on the outboard side?(driver side)
Posted 15 Years Ago
Here are all the numbers.  Inboard, FAA2155A.  Slightly above and to the right of this is a small 5.  Below the FAA is USA.  Below that LD.  Below that 1" DIA.  On the other side is cast, but made to look like a metal tag held on with two screws.  Cast in this "tag" is F20F.  Below that is BB.
layourman
Posted 15 Years Ago
John- I think I am having trouble with e-mail. The master will work! Did you get my private message?
Posted 15 Years Ago
Richard:
I got your pm.  I just now sent a reply.  Let me know if it didn't make it.  I have had problems sending email through forums also.
