Y-Block Powered FED Project
Posted By mctim64 16 Years Ago
mctim64
Posted 16 Years Ago
Last Active: 5 Months Ago
Posts: 2.4K, Visits: 5.0K
got a little more done yesterday. Smile
DSCF3789
DSCF3797
DSCF3787
DSCF3799
Ol'ford nut
Posted 16 Years Ago
Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)
Posts: 322, Visits: 1.2K
I see a dab of something on the rod bearings. What do you use? Also what pistons and rings are you using? Looks to be going together well. Good job!
Ol'ford nutCentral Iowa
56 Vic w/292 & 4 spd.
mctim64
Posted 16 Years Ago
Ol'ford nut (3/4/2010)
I use Sta-Lube moly graphite on the bearings and the cam, but I put Michigan assembly lube in the cylinders (STP works too Wink ) followed buy a couple of squirts of motor oil on the rings before stabbing the pistons in.  The pistons are Kieth Black "Claimers" rings are Sealed Power cast.  I use cast rings on an engine like this so they will seat faster, also with this type of piston the top ring has been moved closer to the top so you need to file them for a larger end gap. (at least .004" per 1" of bore)  I like to give them about .020" gap as I have seen guys forget to do this and bust the top of the piston out when the ends come together.
mctim64
Posted 16 Years Ago
A little more engine "Fun" on Sunday.  Got some good ideas for cockpit  lay-out on Saturday while looking around at the March Meets. Wink
I think I'm going with a foot brake, shifter on the high right side and a small switch panel over the top of the rearend.  None of this is going to be set permanent till I sit in the car and get a feel for what is comfortable and in my reach.
and now my engine. Smile
Hollow Head
Posted 16 Years Ago
Posts: 1.0K, Visits: 3.8K
Tim, the engine looks like....NOSTALGIA BigGrin. One thought, has it ever happened with Y that rockers slide off from push rod due those springs beeing there. In some high revving 4 cylinder race engines (Rallying ones) those springs have been replaced by aluminum tubes to keep rockers in right place.
Keep going, may is just around the corner Tongue.
Here is our cockpit. (wonder where that name comes...) Arrow on the right means "Speed Up" and arrow at the left means "Slow Down" BigGrin. Just to make things easy to remember at 990 feet...w00t.
glrbird
Posted 16 Years Ago
Posts: 616, Visits: 7.1K
Please remember to put you kill switch where you can get to it with gloves on and a hung throtle.  Have seen it several times when rubber or something else is picked up and tossed in the air and sticks on the linkage. If you have some sort of a scoop covering the linkage it is less likley to happen. Food for thought.
Gary Ryan San Antonio.TX.
Park Olson
Posted 16 Years Ago
Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)
Posts: 102, Visits: 1.9K
Tim, I have wondered about the use of sleeves also, lose a tiny bit of tension with them.
Also the removal of material on the the valve end of rocker not in contact with valve.
Daniel Jessup
Posted 16 Years Ago
Posts: 2.0K, Visits: 131.2K
Fill us in on that distributor you have set up...magneto???
Daniel Jessup
Red Lion, Pennsylvania
mctim64
Posted 16 Years Ago
Daniel Jessup (3/9/2010)
It is a Vertex built and donated to Charlie and I by a guy named John Krag.  I was going in the "Brick" but it has now found a new home. Wink
57 ranchwagon
Posted 16 Years Ago
Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)Turbocharged (69 reputation)
Posts: 69, Visits: 303
Tim what kind of front cover is that is it made to run a mechanical pump?
