Distributor replacement cam
Posted By Old Y Block 15 Years Ago
Old Y Block
Posted 15 Years Ago
Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)
Last Active: 14 Years Ago
Posts: 37, Visits: 78
Hi guys; I'm looking for a replacement cam for a B7A-12175-A distributor shaft. For a 57 to 59 y-block V8 distributor with centrifugal and vacuum advance. Thank you very much in advance Smile
Old Y Block Smile
Is this a great site or what??
Posted 15 Years Ago
Is your cam surface worn? I may be in the market for the same item. However, the only supplier that lists them as far as I know, as of their 2007 catalogue, ( I just found out) is Dennis Carpenter Reproductions in N.C.
Old Y Block
Posted 15 Years Ago
PF; Yes my cam is worn. I emailed Carpenter and ask " Does the cam part that acually opens the points included with the shaft"? Their reply was "no". I really did not think so because it was only $20. Their description is mis-leading. So back to square one.  Someone has those on hand, it's just a matter if finding them.
GREENBIRD56
Posted 15 Years Ago
Posts: 1.7K, Visits: 102.7K
I hope I can attach this link because it has some nifty closeups.....Mustang Monthly has some good photo spreads of working on distributors.
http://www.mustangmonthly.com/techarticles/mump_0702_ford_mustang_distributor_rebuild/photo_17.html
Do you suppose the cam of a later Motorcraft dizzy could be grafted to the earlier advance mechanism/stem? Some of the photos almost look like the cam could be pressed off.
I get the Autolite style machined down to accept the Motorcraft "reluctor" to put the Duraspark units in there - why not a later cam?
http://www.mustangmonthly.com/techarticles/mump_0904_how_to_rebuild__autolite_motorcraft_distributors/index.html
There is all sorts of good info in these two articles.
Posted 15 Years Ago
Last Active: 10 hours ago
Posts: 3.7K, Visits: 322.9K
I was leafing through a '69 Hot Rod magazine and saw an article about recurving a Mopar distributor.  There was a picture, and the cam assembly looks identical to the '57-'59 Y.  No guarantee it is a direct replacement, but maybe worth a look-see.  It was a mid or late '60s 383.  I think Mopars used both Autolite and Prestolite ignitions, Autolite may have had a hand in the early Y ones.
