Y Block powered Falcon Gasser
Posted By Glen Henderson 16 Years Ago
aussiebill
Posted 15 Years Ago
Posts: 1.8K, Visits: 11.4K
Glen Henderson (4/16/2011)
Not alky Frank, but it sure ain't running on pump gas. When Ted told me what the C/R was I started looking at what it will take too install a tractor battery. We will give full details after the dyno runs. I am like a kid waiting on Christmas!
Glenn, you may find the heads 2 blocks away on start up? Boy, what comp are you estimating and in what car use is the engine for? thanks, regards billSmile
yyyy
 Down Under, Australia
Glen Henderson
Posted 15 Years Ago
Posts: 1.4K, Visits: 7.5K
No problem Bill, using good ARP head bolts, they should hold the heads in place. Now head gaskets might be another issue. Frank we may have to take some of that good Indiana corn and brew up some special racing fuel if prices keep going up. Like I said earlier, we will print all the engine specs after the dyno results. I have a potential date with Ted on 16 May to pick the engine up, and then we will all know what it will do. I will say, this engine is very similar to Ted's roadster engine.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Y block Billy
Posted 15 Years Ago
Posts: 1.6K, Visits: 5.2K
I have heads with combustion chambers smaller than those domes, make sure you put the recording close to the pipes when you fire it up and post it, I love the cackle of high compression engines.
55 Vicky & customline
yblockpinto312
Posted 15 Years Ago
Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)Turbocharged (63 reputation)
Posts: 51, Visits: 1.7K
Amen to that. I`ve heard Wallys new high compresion motor run, gave me "chicken skin".
Greg Dietrich Mt.Morris Il
yblock32deuce
Posted 15 Years Ago
Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)
Posts: 173, Visits: 1.5K
glenn, i do believe thats the prettiest set of pistons i have ever seen peeping out the top of a block. congrats on being a second time grandpa too. its great!
Glen Henderson
Posted 15 Years Ago
OK, WE ARE MAKING SMOKE!! I talked to Ted today, he had made 5 or 6 pulls and after some set backs with a water leak,  was over 400 hp @ 6200 and he is still tuning on it! I'll be heading out there Sunday so I can be setting in his driveway bright and early Monday morning.
Glen Henderson
Freedom is not Free
Letohatchee, AL
mctim64
Posted 15 Years Ago
Last Active: 5 Months Ago
Posts: 2.4K, Visits: 5.0K
Glen Henderson (5/12/2011)
  was over 400 hp @ 6200 and he is still tuning on it! .
I heard a rumor about that this morning. BigGrin
RB
Posted 15 Years Ago
Posts: 662, Visits: 16.7K
I can sense your excitement Glenn.. It will be nice to apply Y-Block Torque to pavement. Hope you get it finished for Columbus
Glen Henderson
Posted 15 Years Ago
Yes RB, getting excited. Good Lord willing and the creek don't rise, we will be in Columbus.
Ted emailed me a dyno sheet, but dumbass me can't figure out how to convert it from a pdf file to a format that can be posted to the forum, so for now I'll just give the top numbers.
H/P 415.4 @ 6000
TQ 400.8 @ 4700
He was still working with it friday so these numbers may change a little. He was finding that carb spacers were making a huge difference, I'll let him talk about that later. He was having a problem getting the idle down to where he wanted it, but some of that may be the Isky 505 T cam, it was at 1200 rpm and he though that it should be around 1000rpm.
This engine is very basic, so I am well pleased with these numbers.
292 block, 312 crank = 337 ci
mild ported posted G heads (stock dia valves)
Wiseco forged pistons (13 to 1 cr)
Isky 505T cam (Dove rockers)
Mummert intake (stock out of the box)
Eaton modified 750 vac sec Holley carb (830 cfm)
Glen Henderson
Freedom is not Free
Letohatchee, AL
Posted 15 Years Ago
Here’s the dyno sheet for Glen’s 337” Y.  This should make the Falcon a real bird of prey.
