dizzy swap info wanted
Posted By shakey pete 15 Years Ago
shakey pete
Posted 15 Years Ago
Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)
Last Active: 14 Years Ago
Posts: 66, Visits: 211
all this talk about dist. and changing them to electronic  like Msd has anyone compaired a dizzy from a small block 351 windsor or tried to make one fit, or any info would be wellcome Thanks  Shakey Pete from B.CSmile
Posted 15 Years Ago
Last Active: 8 days ago
Do a search on "duraspark deal" and you will see a step by step conversion from Steve(AZ28).Great info
shakey pete
Posted 15 Years Ago
eh shakey Pete here couldn,t find the site you mentioned  but I think that that dizzy would make a great swap if it fit ,I,ll have to go to the junkyard and find oneSmile then compair the 2 they have the small dist cap on them,Smile might be a good swap
Posted 15 Years Ago
Last Active: 9 hours ago
Posts: 4.6K, Visits: 38.5K
Search on this forum! There are some great step by step postings. try:
http://www.y-blocksforever.com/forums/Topic21100-3-1.aspx?Highlight=duraspark+conversion
Chuck in NH
Posted 15 Years Ago
Last Active: 1 hour ago
If you're not up to building one yourself, you should be able to buy one from Performance Distributors in Tenn. I know they've built at least one Y Block specific unit.
Posted 15 Years Ago
Posts: 3.7K, Visits: 323.2K
The 351 won't be a drop in swap because the shaft is too short for a Y to begin with.
shakey pete
Posted 15 Years Ago
so if the shaft is not to long or short enough what swap would you reccomend other than aftermarket, would like to stay all ford !!! Shakey Pete  Thanks JohnSmile
Posted 15 Years Ago
Durospark!w00t Chuck in NH
