dizzy swap info wanted
http://forums.y-blocksforever.com/Topic37450.aspx
By shakey pete - 15 Years Ago
all this talk about dist. and changing them to electronic  like Msd has anyone compaired a dizzy from a small block 351 windsor or tried to make one fit, or any info would be wellcome Thanks  Shakey Pete from B.CSmile
By oldcarmark - 15 Years Ago
Do a search on "duraspark deal" and you will see a step by step conversion from Steve(AZ28).Great info
eh shakey Pete here couldn,t find the site you mentioned  but I think that that dizzy would make a great swap if it fit ,I,ll have to go to the junkyard and find oneSmile then compair the 2 they have the small dist cap on them,Smile might be a good swap
By MoonShadow - 15 Years Ago
Search on this forum! There are some great step by step postings. try:
http://www.y-blocksforever.com/forums/Topic21100-3-1.aspx?Highlight=duraspark+conversion
Chuck in NH
If you're not up to building one yourself, you should be able to buy one from Performance Distributors in Tenn. I know they've built at least one Y Block specific unit.
The 351 won't be a drop in swap because the shaft is too short for a Y to begin with.
so if the shaft is not to long or short enough what swap would you reccomend other than aftermarket, would like to stay all ford !!! Shakey Pete  Thanks JohnSmile
Durospark!w00t Chuck in NH
