9" Socket... plus EXTENSION!?!
Posted By Noob 15 Years Ago
Noob
Posted 15 Years Ago
Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)
Posts: 158, Visits: 1.8K
Doh!!!!
I read that if you can get a socket on the lower bolts of the carrier then you have an 8” rear end.
It was not clear to this noob that the test meant actually being able to remove of the nut with a socket… which would obviously involve a ratchet and an extension.
The socket fits just fine on my 9”… but I’ll be using a box end to remove the nuts. Hehe.
Brian
Cylinder Index = 84
Current Experiment = `57 Tbird, Grand Rapids, Michigan
mongo
Posted 15 Years Ago
Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)
Last Active: 4 Months Ago
Posts: 224, Visits: 556
on the 8" ,you have no problem putting a socket and extension on the bottom nut below the pinion on the case. No so on the the 9"
Po ol Davie
Sparta , Tn.
57FordPU
Posted 15 Years Ago
Posts: 726, Visits: 73.6K
Dave,
Just checking to see if you got my PM.  Please let me know.  Thanks.........
BurnsRacing981@gmail.com
Posted 15 Years Ago
Posts: 3.6K, Visits: 497.7K
mongo (1/6/2010)
I thought it was the opposite
lowrider
Posted 15 Years Ago
Posts: 479, Visits: 10.9K
9in. requires the wrench.
