9" Socket... plus EXTENSION!?!
http://forums.y-blocksforever.com/Topic37244.aspx
By Noob - 15 Years Ago
Doh!!!!
I read that if you can get a socket on the lower bolts of the carrier then you have an 8” rear end.
It was not clear to this noob that the test meant actually being able to remove of the nut with a socket… which would obviously involve a ratchet and an extension.
The socket fits just fine on my 9”… but I’ll be using a box end to remove the nuts. Hehe.
Brian
By mongo - 15 Years Ago
on the 8" ,you have no problem putting a socket and extension on the bottom nut below the pinion on the case. No so on the the 9"
By 57FordPU - 15 Years Ago
Dave,
Just checking to see if you got my PM.  Please let me know.  Thanks.........
By paul2748 - 15 Years Ago
mongo (1/6/2010)
I thought it was the opposite
By lowrider - 15 Years Ago
9in. requires the wrench.
