Noob
Visits: 1.8K
... anyway, I've no good local source for lengthening my drive shaft and changing the joint ends for the T-5 swap. Looking for any first hand recommendations for a 'mail order" shaft. Found a company online called Denny's Drive Shafts that has a pretty good Worksheet for specifying dimensions. Any recommended sources for a 'custom' driveshaft? thanks... brian
Cylinder Index = 84 Current Experiment = `57 Tbird, Grand Rapids, Michigan
kidcourier
Visits: 8.8K
Noob, Don't know where your located but have had good luck with (Inland Empire Driveline in either Ontario or Corona,Calif.)or go to google and search--driveline service and take your pick! KID
I used Denny's. They provide an excellent service. I like their twist or break it replacement policy. I haven't had to use it. The free lifetime labor is good, too. I did use this when I installed the T5. Even with the cost of shipping, modifications are cheaper than getting it done down the street.
Nathan Soukup
Visits: 339
Inland Empire Drivelines do pretty good.Guys that make driveshafts tend to be pretty grumpy,they seem to be polite.I usually just measure what I need and go to the junkyard.Ive had good luck with GOOD original driveshafts from FORD from the junkyard as long as they arent damaged.
55 fairlane gasser 312 /c4, 57 f100 292/c4, 52 mainline gasser 302/t10 4speed
gritsngumbo
Visits: 2.2K
charliemccraney (1/3/2010) I used Denny's. They provide an excellent service. I like their twist or break it replacement policy. I haven't had to use it. The free lifetime labor is good, too. I did use this when I installed the T5. Even with the cost of shipping, modifications are cheaper than getting it done down the street.Charlie: Do you have a link or a phone # handy for Denny's?
Gerald Ingram aka "Gritsngumbo" Monroe, LA LITTLE RED: 64 Ford F100 Short Bed Styleside BIG RED: 63 Ford F100 Long Bed Unibody BBW RED: 61 Ford F100 BBW Long Bed Custom Cab Unibody BIG “UN: 63 F250 Longbed Flareside CREW CAB: 63 F100 "Stageway" Crew Cab w/Long "Wrong" Bed
Noob
Visits: 1.8K
Try this one... http://www.dennysdriveshaft.com/ I ordered mine about a week ago... busy season for them so they saying three week lead time. Very thoughtful and detail oriented on the phone. Will update and post pics once I receive. Cheers... Brian
mongo
Visits: 556
Quarter master , as in clucthes , makes tons of driveshafts for nascar, also there was a guy on ebay, who had maybe 100 used nascar drive shafts, for around $75 each complete different sizes.
Po ol DavieSparta , Tn.
Noob
Visits: 1.8K
I went with Denny's Driveshafts and a good experience/value... thought to share a pic of the old shorter steel one and the new aluminum one from Denny's. Also in the pic is a 9" Trac Loc to replace the stock open differential.
Cheers... Brian
