Drive Shaft Source
http://forums.y-blocksforever.com/Topic37110.aspx
By Noob - 16 Years Ago
... anyway, I've no good local source for lengthening my drive shaft and changing the joint ends for the T-5 swap.  Looking for any first hand recommendations for a 'mail order" shaft.  Found a company online called Denny's Drive Shafts that has a pretty good Worksheet for specifying dimensions. Any recommended sources for a 'custom' driveshaft?
thanks... brian
By kidcourier - 16 Years Ago
Noob, Don't know where your located but have had good luck with (Inland Empire Driveline in either Ontario or Corona,Calif.)or go to google and search--driveline service and take your pick! KID
I used Denny's. They provide an excellent service. I like their twist or break it replacement policy. I haven't had to use it. The free lifetime labor is good, too. I did use this when I installed the T5. Even with the cost of shipping, modifications are cheaper than getting it done down the street.
By Nathan Soukup - 16 Years Ago
Inland Empire Drivelines do pretty good.Guys that make driveshafts tend to be pretty grumpy,they seem to be polite.I usually just measure what I need and go to the junkyard.Ive had good luck with GOOD original driveshafts from FORD from the junkyard as long as they arent damaged.
By gritsngumbo - 16 Years Ago
charliemccraney (1/3/2010)
Charlie: Do you have a link or a phone # handy for Denny's?
Try this one...  http://www.dennysdriveshaft.com/
I ordered mine about a week ago... busy season for them so they saying three week lead time.
Very thoughtful and detail oriented on the phone.
Will update and post pics once I receive.
Cheers... Brian
By mongo - 16 Years Ago
Quarter master , as in clucthes , makes tons of driveshafts for nascar, also there was a guy on ebay, who had maybe 100 used nascar drive shafts, for around $75 each complete different sizes.
I went with Denny's Driveshafts and a good experience/value... thought to share a pic of the old shorter steel one and the new aluminum one from Denny's. Also in the pic is a 9" Trac Loc to replace the stock open differential.
Cheers... Brian
