T-5 Spacer/Adapter Plate
Posted By Noob 17 Years Ago
John Mummert
Posted 17 Years Ago
Last Active: 2 Weeks Ago
Posts: 918, Visits: 7.5K
The adapter is 3/4" .750" or 19.05mm thick,depends on the mood we're in that day. The original adapters were not rotated because the bottom 2 bolt holes actually line up with the 49-64 bellhousing. This made mounting the transmission easy but the rear mount was rotated making the crossmember a pain.
The rotated version moves the shifter closer and makes the rear mount easier but makes mounting the adapter to the bellhousing a little more involved.
The pilot portion of input shaft must be shortened 1/4" so it doesn't bottom in the back of crankshaft. If the adapter is made thick enough so that the input shaft doesn't need to shortened you won't get full engagement of the splines.
http://ford-y-block.com
Posted 17 Years Ago
Posts: 3.7K, Visits: 323.4K
Bill:
I come up with 19.05 mm, but that is a moot point because Ys are built to fractional sizes, so the related parts should be fractional also.  Just had to pull your chain a little, lol.
shakey pete
Posted 17 Years Ago
Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)Turbocharged (66 reputation)
Last Active: 15 Years Ago
Posts: 66, Visits: 211
.750 is the same as 3/4 of an inch Tongue
yehaabill
Posted 17 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
Y-Guy Noob:              18.? mm...................
                                           Bill
Bill
Pelham,Al
Noob
Posted 17 Years Ago
Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)
Posts: 158, Visits: 1.8K
Ok fellas... noob here... which is it, 3/4" OR .750 ???? Geesh... now I'm gonna have to make two different spacer sets... Hehe
Cylinder Index = 84
Current Experiment = `57 Tbird, Grand Rapids, Michigan
Tom Compton
Posted 17 Years Ago
Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)
Posts: 287, Visits: 4.0K
It has been several years but recall the thickness being .750" and therefore did not need to shorten the input shaft.
You gotta have the right tools and know how to use 'em.
TC - Austin, Texas
Noob
Posted 17 Years Ago
Cool beans, Bill... I have an empty T-5 case and tail coming next week for mock-up and now I can make some temp spacers (+/- 1/16", lol) to see whats what.  I may still have to bug John, cuz I understand the new plates have a clockwise rotation to postion the shifter closer to the driver. Thanks again, Bill for the measure.
Cheers... Brian
Cylinder Index = 84
yehaabill
Posted 17 Years Ago
Y-Guy Noob        Sorry it took so long to get the measurement, it's
                  3/4" thick give or take a 1/16".
                                                     Bill
Bill
Pelham,Al
yehaabill
Posted 17 Years Ago
Y-Guy Noob:      I'll try to measure mine wednesday and get back to you.
                                               Bill
Bill
Pelham,Al
Noob
Posted 17 Years Ago
I didnt want to bug John just yet, but need to know the thickness of the adaptor plate he sells for affixing a T-5 tranny to a Y.  If anybody knows the amount of rotation his new design offers that would  be great too.
I'm awaiting a gutted case and tail section so I can mock-up investigate frame and tunnel mods will be necessary before cut'n and weld'n.
Thanks in advance for any replies.
Cheers... Brian
Cylinder Index = 84
