Last Active: 14 Years Ago
Visits: 437
I"m looking for a 1955 Mercury teapot carb. for a 292 cu. in engine. Does anybody know what number carb. I need? Does anybody know where I can find either re-buildable or re-build one! I have a auto tranny. I think the carb I need is either a B5A-9510-R or B5A-9510-N? I'm also looking for a oil pickup tube for a front sump oil pan. tube that runs from oil pan sump to oil pump.
roviwancanobe
Last Active: 6 days ago
Visits: 20.6K
I have the following 55 t pot carbs (1 )eck-9510-s list 1075-1 (2) eck 9510-t list 1074-1 (1) eck 9510-f h list 1074. the 55 carbs have the choke located on the intake manifold. The carbs are complete but will need cleaned and rebuilt. Carl Ohio
Posts: 3.3K,
Visits: 238.8K
Rovison: Some Merc's may also have come with Carter carbs. (model?) However, I may be incorrect on that info. Someone will confirm or correct me..
Visits: 437
How much for the eck 9510-T. emmytom@msn.com
roviwancanobe
Visits: 20.6K
I sent you a PM on the carb Carl
Visits: 437
Thanks Chuck, M/O on its way. Tom
roviwancanobe
Visits: 437
thanks to Carl not Chuck my mistake Tom
roviwancanobe
Posts: 1.3K,
Visits: 9.2K
Paul, some 56 mercs came with the Carter carbs, not sure about 55s.
-Gary Burnette-
Visits: 437
Thanks for all the HELP !!
roviwancanobe
Visits: 181
Do everything you can to keep from using the teapot. Like find a 56 4bbl intake and a Carter WCFB, much better set up but only my 2 cents worth. If you are a purist and want to stay totally original teapot it is. As the man said in 56 they used Carters, there is a reason for it.
Terry
