New Aluminum air cleaner and valve covers
Posted By BFOOTER03 16 Years Ago
BFOOTER03
Posted 16 Years Ago
Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)
Posts: 323, Visits: 1.2K
Got some pictures from Gord on his new air clean and valve covers.  Looks like he was finally able to reproduce the T-bird logo on both.  Said aluminum heards are next on his list.  Bing
Warsaw, IN
Ketterbros
Posted 16 Years Ago
Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)
Posts: 132, Visits: 2.8K
The filter set up would be great if it works with tea pots, bigger filter element...??
Brother and I own/operate 1957 Ford Fairlane 312/4x2 and two 1963 Falcons 302 rollers carburated 600cfm, FE427 sitting in shed..
sundance241
Posted 16 Years Ago
Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)
Posts: 202, Visits: 1.4K
Bfooter ,    any prices on these items ?....Sam
56 victoria
BFOOTER03
Posted 16 Years Ago
Gord did mention he is working on a tea pot air cleaner but it is not ready at this time.  Sam no prices were mentioned but will see if I can get some for you.  Bing
Warsaw, IN
BFOOTER03
Posted 16 Years Ago
Straight form the man himself.  Bing
We manufacture the T-Bird Air Filter in 5 versions. Here is a list of the versions and the associated cost:
Single 4 Barrel (’57 and newer Holley carb – large bolt pattern) - $250
Single 4 Barrel (’55 and ’56 Holley carb [teapot] – small bolt pattern) - $300
Tri-Power - $330
Dual 4 Barrel carbs (Edelbrock and Carter AFB carbs) - $330
Dual 4 Barrel carbs (Holley teapot – small bolt pattern) - $380
The T-Bird air filters are available in “as cast” and polished finish…there is a $100 adder for the polished top.
Warsaw, IN
Posted 16 Years Ago
Since this announcement, is for some of us, out of the blue, who and where is Gord?
BFOOTER03
Posted 16 Years Ago
CKiller, you are correct the carb spacing even on the 3x2's are different from mfg to mfg and yes I am some what of a go between.
Paul, Gord is a guy from north of the boarder (Canada) who makes a super charger for the Y as well as the parts in this thread.  If you look on Epay every now and then he lists a super charge to sell.  He wrote a couple articles a few years back for the Y Block Magazine.  I have mentioned the site to him several times but for some reason he has not joined.  Bing
Warsaw, IN
Posted 16 Years Ago
Last Active: 7 hours ago
Posts: 3.7K, Visits: 322.9K
Isn't that the Gord that was banned from advertising in YBM several years ago?
noslo56
Posted 16 Years Ago
Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)
Posts: 5, Visits: 11
There are versions of the air filter available that fits the Holley "teapot" carbs...both for single and dual 4 barrel intakes. The filter element is 4" tall to accomodate the extra height of the teapot.
Gord
noslo56
Posted 16 Years Ago
You are correct...there is a slight difference in the carb to carb spacing between the Edelbrock and Offy intakes. When ordering the air filter for the tri-power setup, you have to specify which intake you are using.
Gord
