By BFOOTER03 - 16 Years Ago
Got some pictures from Gord on his new air clean and valve covers. Looks like he was finally able to reproduce the T-bird logo on both. Said aluminum heards are next on his list. Bing
By Ketterbros - 16 Years Ago
The filter set up would be great if it works with tea pots, bigger filter element...??
By sundance241 - 16 Years Ago
Bfooter , any prices on these items ?....Sam
Gord did mention he is working on a tea pot air cleaner but it is not ready at this time. Sam no prices were mentioned but will see if I can get some for you. Bing
Straight form the man himself. Bing We manufacture the T-Bird Air Filter in 5 versions. Here is a list of the versions and the associated cost: Single 4 Barrel (’57 and newer Holley carb – large bolt pattern) - $250 Single 4 Barrel (’55 and ’56 Holley carb [teapot] – small bolt pattern) - $300 Tri-Power - $330 Dual 4 Barrel carbs (Edelbrock and Carter AFB carbs) - $330 Dual 4 Barrel carbs (Holley teapot – small bolt pattern) - $380 The T-Bird air filters are available in “as cast” and polished finish…there is a $100 adder for the polished top.
By PF Arcand - 16 Years Ago
Since this announcement, is for some of us, out of the blue, who and where is Gord?
CKiller, you are correct the carb spacing even on the 3x2's are different from mfg to mfg and yes I am some what of a go between. Paul, Gord is a guy from north of the boarder (Canada) who makes a super charger for the Y as well as the parts in this thread. If you look on Epay every now and then he lists a super charge to sell. He wrote a couple articles a few years back for the Y Block Magazine. I have mentioned the site to him several times but for some reason he has not joined. Bing
Isn't that the Gord that was banned from advertising in YBM several years ago?
By noslo56 - 16 Years Ago
There are versions of the air filter available that fits the Holley "teapot" carbs...both for single and dual 4 barrel intakes. The filter element is 4" tall to accomodate the extra height of the teapot. Gord
You are correct...there is a slight difference in the carb to carb spacing between the Edelbrock and Offy intakes. When ordering the air filter for the tri-power setup, you have to specify which intake you are using. Gord
You can contact me by email at REXREP@telusplanet.net Gord
No info was given as to why. And I was in error to wonder if this Gord is the same Gord. I hope I am wrong. Sorry, Gord.
By aussiebill - 16 Years Ago
Hi john, why dont you PM him and ask, then that question should be cleared up for once. Best regards bill.
