cruise control
Posted By rexbd 16 Years Ago
rexbd
Posted 16 Years Ago
Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)
Posts: 128, Visits: 1.5K
Anyone ever put an aftermarket cruise control on a Tbird.  Toying with the idea but would want to do in as stealth a mode as possible.  Any recomendations on manufacturers.
PS.  if you think I'm nuts, I've been told that before
Posted 16 Years Ago
Posts: 3.6K, Visits: 497.7K
I put a cruise control in my 56 Bird last year. Not really stealthy as the governor unit sits in the inner fender panel. Its an Audiovox CCS-100 and it works pretty good, but not as good as the factory installed units in my everyday cars. I has a bit of trouble getting it going at first, but it worked good on my trip to Oregon and back (from NJ). I got it off ebay.
bird55
Posted 16 Years Ago
Posts: 1.1K, Visits: 58.8K
It's important to me that it be stealthy as well or at least uncluttered. I would also like to hear more about this subject.
You might check with Rostra controls and see what there is to offer and let us know what you find out. I've seen several birds with cruise, just wasn't paying much attention to the setup at the time.
webconst
Posted 16 Years Ago
Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)
Posts: 48, Visits: 5.8K
I have installed Audiovox vacuum units on 5, 6 & 7 T-Birds with good results.  Changed '57 to Audiovox Unltracruise II mounted on firewall.  Works great.  They offer a dash mount and turn signal control.  Going to try and install their rear collision avoidance and clear lane reset behind grill.  I recommend to change to mechanical brake light switch with any cruise control.  Charlie
DANIEL TINDER
Posted 16 Years Ago
Last Active: 5 hours ago
Posts: 1.7K, Visits: 154.2K
I wonder if the available (radio conversion) 6Vpos to 12Vneg transformers would provide enough juice to power the Audiovox?
6 VOLTS/POS. GRD. NW INDIANA
mr.uglyduckling
Posted 16 Years Ago
Supercharged (88 reputation)Supercharged (88 reputation)Supercharged (88 reputation)Supercharged (88 reputation)Supercharged (88 reputation)Supercharged (88 reputation)Supercharged (88 reputation)Supercharged (88 reputation)Supercharged (88 reputation)
Posts: 77, Visits: 181
try dakota digital i looked into them and they seemed pretty good
"young bucks bring fresh ideas sometimes they work sometimes they dont but all the same it was an idea it wasnt the first it wont be the last either!"
55thunderbird
Posted 15 Years Ago
Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)
Last Active: 15 Years Ago
Posts: 5, Visits: 21
I installed a Dakota Digital on a customer's '57 Thunderbird last Fall. Works great.
55thunderbird
Posted 15 Years Ago
I have heard of a unit made by Rostra Precision Controls which is supposed to be "stealthy" A person I know installed one of these and is very happy with it.
kcblueoval
Posted 15 Years Ago
Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)
Posts: 24, Visits: 252
The Dakota Digital units are about $150. at most HOD ROD supply stores. I don't know how stealthy they are. A buddy talked to their reps at shows & the reps know their stuff about how they work, etc. I think they are pretty compact. I think they drive off your speedo cable. I think they offer a couple different ways to control speed. My buddy plans to get one for his "46 Coupe with 302 SBF & C4.
Good Luck
kcbluoval
junkyardjeff
Posted 15 Years Ago
Posts: 813, Visits: 3.4K
After the trip to Daytona my 55 could use it too.
