Remote oil filter
Posted By MoonShadow 19 Years Ago
Posted 19 Years Ago
Last Active: 8 minutes ago
Posts: 4.6K, Visits: 39.4K
Will any of the later remote oil filter adapters fit the Y-Block? Chuck
Glen Henderson
Posted 19 Years Ago
Posts: 1.4K, Visits: 7.5K
I think so, as long as you have the spin on filter adapter, I see no reason that they wouldn't work. Ford had a right angle filter adapter, I think it was used on some H/D trucks.
Glen Henderson
Freedom is not Free
Letohatchee, AL
46yblock
Posted 19 Years Ago
Posts: 1.2K, Visits: 7.8K
The remote setup requires a bypass adaptor for the block which attaches to your existing spinon adaptor, and the actual remote filter holder which is mounted wherever you choose.  Quite a few suppliers have them.  Speedway, AutoZone, and others.  Mine is a Haynes that came from Autozone.  Make sure the hoses going from the bypass to the oil filter recepticle are high pressure, hydraulic rated.  Not run of the mill water heater hose.  Speedway has the hose in either blue or black.
Mike
Posted 19 Years Ago
Which bypass adapter? If I remember correctly the SBF 289/302 ones work. Don't want to buy the wrong thing! Chuck
46yblock
Posted 19 Years Ago
http://www.speedwaymotors.com/p/1158,,_Remote-Bypass-Adapters.html?itemNo=REMOTE+OIL+FILTER
This Speedway bypass #7201013 would work, or any bypass with the 3/4 "-16 thread.  Many Ford motors use the same one.  FYI the Haynes unit has two options on the same bypass for hose attachment.  One with hoses running roughly parallel to block, and the other has the hoses going straight out from the block.  You just plug the two that arent used.  It gives a little more flexibility.
Mike
carl
Posted 19 Years Ago
Posts: 1.2K, Visits: 20.7K
chuck i have a 57 312 in the garage that has a Hildebrand remote filter adapter on it.it has two fittings  one in the center and one on the outer edge.i didnt take it off to see what the inside looks like  carl
Frankenstein57
Posted 19 Years Ago
Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)
Posts: 131, Visits: 891
If your into salvage parts, I pulled a nice remote filter cooler setup off of a 88 e350 460 econoline van. My wifes windstar 3.8 has one too. happy hunting, Mark
thanks, Mark
