Casting number for 292 truck engine with steel crank
Posted By jakdad 16 Years Ago
jakdad
Posted 16 Years Ago
Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)Hitting on all eight cylinders (9 reputation)
Last Active: 14 Years Ago
Posts: 9, Visits: 50
Anybody know this? I tried the search but no help. Great site, thought you folks might know this.
Thanks,
 Jim
Jim
bloodyknucklehill
Posted 16 Years Ago
Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)Supercharged (242 reputation)
Posts: 242, Visits: 2.2K
C1TE i believe.. it was only available in heavy duty applications so if you're looking for one big Ford Trucks of the era is your best bet..
Dustin
Southern Oregon Y's Guy Cool
http://www.facebook.com/?ref=home#/profile.php?ref=profile&id=1441322018
jakdad
Posted 16 Years Ago
Is C1TE the block or crank?
 Thanks,
Jim
bloodyknucklehill
Posted 16 Years Ago
i think it's the number for the crank.. the block code would more than likely be a either C1AE or C2AE since it was only used in heavy duty trucks from 61 to 64..
Dustin
Ol'ford nut
Posted 16 Years Ago
Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)
Posts: 322, Visits: 1.2K
Look here for all the numbers (and more!)
http://www.ford-y-block.com/index.html
Ol'ford nutCentral Iowa
56 Vic w/292 & 4 spd.
Posted 16 Years Ago
Posts: 6.1K, Visits: 442.6K
If you're buying an engine in hopes of acquiring a forged crank, the best thing o do is to look at the crank flange and/or pull the oil pan.
The same block casting was used with cast and forged cranks.
mctim64
Posted 16 Years Ago
Posts: 2.4K, Visits: 5.0K
There is no specific truck block but the C1AE or C2AE are your best bet. You should still pull the pan to make sure of the crank.
http://yblockguy.com/
crenwelge
Posted 16 Years Ago
Posts: 512, Visits: 1.7K
The steel crank was only used in truck engines for a few years. It was very common to buy a used crank instead of having one turned 45 years ago. Trucks were even more vulnerable to having a salvage yard crank installed because they were driven a lot of miles and subjected to a lot of abuse. They might not break, but they sure turned blue when they were run low on oil. If you really want a steel crank, make sure you identify it.
Kenneth
Fredricksburg, Texas
y-block don
Posted 16 Years Ago
Turbocharged (71 reputation)Turbocharged (71 reputation)Turbocharged (71 reputation)Turbocharged (71 reputation)Turbocharged (71 reputation)Turbocharged (71 reputation)Turbocharged (71 reputation)Turbocharged (71 reputation)Turbocharged (71 reputation)
Posts: 71, Visits: 478
would that be the same for a 63-64 school bus  as i have  a complete y out of a bus for 200$ complete oil pan to carb and still has the bellhousing and all attached and is the truck block the same as a car ?
y-block newbie
jakdad
Posted 16 Years Ago
y-block don (9/16/2009)
 Email sent
Jim
