Casting number for 292 truck engine with steel crank
http://forums.y-blocksforever.com/Topic31791.aspx
By jakdad - 16 Years Ago
Anybody know this? I tried the search but no help. Great site, thought you folks might know this.
Thanks,
 Jim
By bloodyknucklehill - 16 Years Ago
C1TE i believe.. it was only available in heavy duty applications so if you're looking for one big Ford Trucks of the era is your best bet..
Is C1TE the block or crank?
 Thanks,
i think it's the number for the crank.. the block code would more than likely be a either C1AE or C2AE since it was only used in heavy duty trucks from 61 to 64..
By Ol'ford nut - 16 Years Ago
Look here for all the numbers (and more!)
http://www.ford-y-block.com/index.html
If you're buying an engine in hopes of acquiring a forged crank, the best thing o do is to look at the crank flange and/or pull the oil pan.
The same block casting was used with cast and forged cranks.
By mctim64 - 16 Years Ago
There is no specific truck block but the C1AE or C2AE are your best bet. You should still pull the pan to make sure of the crank.
http://yblockguy.com/
By crenwelge - 16 Years Ago
The steel crank was only used in truck engines for a few years. It was very common to buy a used crank instead of having one turned 45 years ago. Trucks were even more vulnerable to having a salvage yard crank installed because they were driven a lot of miles and subjected to a lot of abuse. They might not break, but they sure turned blue when they were run low on oil. If you really want a steel crank, make sure you identify it.
By y-block don - 16 Years Ago
would that be the same for a 63-64 school bus  as i have  a complete y out of a bus for 200$ complete oil pan to carb and still has the bellhousing and all attached and is the truck block the same as a car ?
y-block don (9/16/2009)
 Email sent
By Park Olson - 16 Years Ago
I believe the 700  series was the largest truck to use the 292 as a  base engine, the most likely suspect for a steel crank.
Thanks Park, That sounds right.
